Running like sh#$, need help.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chev4life, Aug 14, 2001.
  1. chev4life
    chev4life 1/2 ton status
    Jun 21, 2001
    416
    San Jose, CA
    I have an '87 k5 350 TBI and have had a stumble/stall problem for awhile now, the thing will run fine and then decide to stumble and wont rev, then it would suddenly jump up to idle after slamming the gas pedal a few times and then run fine and then do the whole thing over again, sometimes just stalling out completely. I first thought it was the fuel filter, so I changed it and she ran fine....a few days later did the same thing. So I finally said fu$* it and put a new gas tank, sending unit(needed one anyway), fuel pump, and filter on and she ran fine for about 350 miles and now is doing the same thing again. I cant seem to figure it out...any suggestions??? Could it be my injectors? I still have my stock fully rusted out exhaust.....could that be the prob....maybe clogged cat????? HELP!
  2. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    Are you getting an engine light?
    No prohibiting allowed!!!!
    <a target="_blank" href=http://www.geocities.com/muddin4fun79blazer/>http://www.geocities.com/muddin4fun79blazer/</a>
  3. BigTex
    BigTex 1/2 ton status
    Dec 27, 2000
    974
    South Texas
    You always have to check the simplest things first, and it sounds to me like you have a clogged TBI. My dad had a similar problem with his '88 pickup. We cleaned the TBI with Gunk and it ran fine for a while. We then replaced the filter, it ran fine again for a while. Then we replaced the pump and that was the problem. But with you, since you have already done these things, I would say to definitely clean the injector. It may also need replacing if you have high mileage.
    <a target="_blank" href=http://www.chriswhitley.com>www.chriswhitley.com</a>
  4. chev4life
    Jun 21, 2001
    416
    San Jose, CA
    I rarely have the engine light come on, but every once in awhile it does. It does come on when the engine dies though. What is the best way to clean the injectors????...should I remove them first or is there another way...I really dont want to have to take the beast into the shop. Do I need anything special to remove the injectors??
  5. BigTex
    Dec 27, 2000
    974
    South Texas
    Well, to start, just buy a can of injector cleaner at a parts store. Then just follow the instructions (some may have different instructions than others). But all you really need to do is spray it in there like you would a carburetor. Just make sure to get every nook and cranny. Keep in mind, though that that only cleans the surface for the most part. I would also get one of those cleaners that you dump in the gas tank. Believe it or not, and I know some people will disagree with me on this one, running regular unleaded gas as opposed to premium can also make a big difference. It does for my rig. Replacing an injector is pretty easy too, I think. OH! I almost forgot to tell you--be sure to check ALL your fuel lines as thoroughly as possible. You may have some cracked lines.
  6. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    Get the little code thing and find out what code it stored in the puter. It can tell you a bunch!
  7. Hayduke
    Hayduke 1/2 ton status
    May 9, 2000
    271
    NE Columbus, Ohio
    try cleaning it out with the spray, then run 1/4 tank of premium gas with a cleaning additive in it, find a long lonesome road and floor it for a bit, if that doesn't do the trick then mech. work is needed. also cleck all the lines for cracks/kinks....
    good luck!
    peace.
    HAYDUKE
    Insured By COLT, Policy #.357M
    <a target="_blank" href=http://haydukesk5.coloradok5.com>http://haydukesk5.coloradok5.com</a>
  8. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    My brother-in-law just went through a whole whack of similar trouble. After swapping out this part and that part, it ended up being a blown EGR valve.........
    <font color=red>PHOTO ALBUM-</font color=red> <a target="_blank" href=http://albums.photopoint.com/j/AlbumList?u=1289798>http://albums.photopoint.com/j/AlbumList?u=1289798</a>.......<font color=blue>TRUCK & HIKING PICS</font color=blue>
  9. chev4life
    Jun 21, 2001
    416
    San Jose, CA
    Did he have the same stumble crap that I mentioned???
  10. husurddy
    husurddy 1/2 ton status
    Jul 28, 2001
    108
    Snow Hill, Maryland, go east \'till you hit water
    I had kind of the same problem, but mostly stalled coming off idle. Come to find out the brand new EGR was bad (Stuck open) But cant tell if this is whats happening to you. I would also check your fuel and fuel return lines, they could easily get bent during engine/chassis work
  11. Can Can
    15,552
    136
    His problem was MOSTLY at idle, but sometimes it would feel "boggy" at speed, too. His fuel mileage started getting pretty bad as well.
  12. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    I had the exact same problem with my K5 and an EGR valve...
    <font color=blue> Jeff - may the force be with you</font color=blue>
    <a target="_blank" href=http://coloradok5.com/gallery/Jeffs-Stuff>http://coloradok5.com/gallery/Jeffs-Stuff</a>
  13. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Can I bring up one other small thing? Where are you getting your gas from? You say that for say 350 miles it runs ok, then it'll start again. this is just another free cheap thing to think about. The station your getting gas from might have a full tank of crap. Just a thought.
    But if that aint it, I'd go for the injector cleaner then maybe the egr valve.
    The check engine light will come when the engine stalls. If its flashing while running, then you need to figure out the code its giving.
    In search for the sound of frying bacon!! [​IMG]
    3/4 in progress[​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
  14. RESTORE89
    RESTORE89 1/2 ton status
    Jan 31, 2001
    548
    CHAS SC
    check the filter again
    if you changed and it got better and then started again you could have crud in the lines and be clogging the filter, but definately get teh little code reader and see what the computer tells you, when i first got my 89 i ended replacing almost all of the emissons sensors to get it to run right
    It needs a bigger motor.
    what's in it now?
    doen't matter it NEEDS A BIGGER MOTOR
    89 350tbi/700r4h/np208/4.11's
