running on board air and A/C
Discussion in 'The Garage' started by hi pinion, Jun 29, 2004.
  1. hi pinion
    hi pinion 3/4 ton status
    Sep 25, 2003
    5,354
    **PLUMBING THE WORLD**
    Has anyone addaed a york pump.....withought removing the stock a/c pump????If so,what is involved? /forums/images/graemlins/dunno.gif /forums/images/graemlins/thumb.gifAnyone????
  2. dawson444
    dawson444 1/2 ton status
    Jul 5, 2000
    1,034
    Raleigh, NC
    You have to make custom brackets, which is a PITA. I think the best place to put the york is where the stock air pump was and use the pulley off the engine that drove the air pump.
  3. BIGJ
    BIGJ 1/2 ton status Author
    896
    Central Arkansas
    There's one in the tech section here.
    BIGJ
  4. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    BIGJ
    [/ QUOTE ]Thanks, Hipinion and I both want on board air but don't want to give up our A/C's.
  5. hi pinion
    Sep 25, 2003
    5,354
    Have you even heard of anyone doing this?????i would like to see how much of a PITA it is.Be cool if someone had an aftermarket bracket. /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif Anyone???? /forums/images/graemlins/dunno.gif
  6. hi pinion
    Sep 25, 2003
    5,354
    Is that WITH a/c???? /forums/images/graemlins/dunno.gif
  7. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    I have been thinking about doing the same thing. Basically, I am going to try to run the york on the pass. side of the engine and mount it where my smog pump used to be. I'll see if I can modify my smog pump brackets to work. If not, At least I'll get measurements from them to fabricate some new ones. I have the option of doing that because I don't need to run emissions on my '74. It might not help you guys though. /forums/images/graemlins/dunno.gif
    /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gifIf you have to run a smog pump and want to keep your AC, you may be better off running a small heavy duty 12V compressor. You can mount them to the top of your inner fender under the hood, or, they make them small enough so that you could mount them just about anywhere under your truck tucked up inside the frame. I know they make some that are pretty heavy duty and will run air tools quite well. It might be worth some research.
  8. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Depending on the year of your truck. The alternator has a ribbed pulley or a v-groove pulley. If it has the ribbed pulley OBA makes a replacement pulley that is a ribbed pulley with a v-groove to allow you to run a york from your alternator all you have to do is make brackets to mount the york beside the alternator.
  9. hi pinion
    Sep 25, 2003
    5,354
    [​IMG] Hey shane,is this something similar to what your talking about? /forums/images/graemlins/thumb.gif
  10. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    Yep! Looks similar to some I have found while researching this. I may go with one anyway. Much easier to run some wires and bolt the sucker down than fabbing up brackets and routing hoses around the engine. Not as cheap as a York setup, but really clean looking IMO /forums/images/graemlins/thumb.gif
  11. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    I just built my serpentine york bracket W/ a/c (that doesnt work). I'll get pics on saturday but my fabrication blows. Maybe the general idea will help you though. I kept the v-groove pulley on the york and am going to run a combo pulley off the alternator. Building the bracket wasnt that hard and I'm a wee-begginer fabber.
  12. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    i know willyswanter has an electric one (not motor driven) anyway post a link to the pic you have there, i want to find a GOOD on that is not engine driven. do you have any suggestions?
  13. hi pinion
    Sep 25, 2003
    5,354
  14. hi pinion
    Sep 25, 2003
    5,354
    [/ QUOTE ] Id like to see that /forums/images/graemlins/thumb.gif
