Running out of diesel
Discussion in '1982-Present GM Diesel' started by 78GMC1/2TON4x4, Nov 25, 2004.
  1. 78GMC1/2TON4x4
    78GMC1/2TON4x4 1/2 ton status
    Mar 10, 2003
    167
    Mount.Angel, OR
    There has to be an easier way or ridding the air out of the system right? like when my truck has run out of diesel a few times its because the gauge barely works. 1/4 tank on that means damn near empty. the bobcat we have at work when it runs out you fill it back up, crack open a vavle deal and pump a rubber ball to force the air out and diesel in. then it fires right up...sometimes im workin on 2-3 hours to get mine started with the battery so weak and all. jumpin thpse dual batteries takes forever! any help would be sweet! /forums/images/graemlins/truck.gif
  2. bigblock454
    bigblock454 Clack Clack Clack Premium Member
    Jun 18, 2002
    546
    16
    Terre Haute IN
    Crack open a couple of the injector lines while cranking to purge out the air. Once fuel starts coming out tighten it up.
  3. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    thats how I have always done it as well on every last one I've worked on /forums/images/graemlins/waytogo.gif
  4. Blazr77400
    Blazr77400 1/2 ton status
    Aug 31, 2001
    652
    Ogden, UTAH
    When I was doing the injector pump and fuel tank swap, I got a small electric pump from checker and temporarily hooked it up, then I pressurized the tank with about 2psi. That way you dont have to run the starter to get the fuel system bled. It started right up everytime. Seems like a pain but, once you do it and see how easy it is you wont do it any other way. /forums/images/graemlins/truck.gif
