Running radials and bias plys at the same time
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by xnoahx, Jul 23, 2001.
  1. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    i heard somewhere that you shouldnt run radial tires with bias ply tires somewhere, and i was just wondering if you really arent supposed to do it. Also, what is better, radial or bias? Im wondering because its almost time to replace two of my tires(36" Swampers) and i would like to go with the radials if they wear better and are safer. but i will still have two bias tires on the truck.
    Check out my 73 K5 <a target="_blank" href=http:// members.theglobe.com/xnoahx/73k5.htm > members.theglobe.com/xnoahx/73k5.htm </a>
  2. denver75k5
    denver75k5 1/2 ton status
    May 15, 2001
    1,017
    Somewhere In The Woods
    Re: Running radials and bia plys at the same time
    I've heard the same thing, that is not run bias with rad.
    As far as wich one is better , Bias are a little tougher, but thats about all I know about them.
    <a target="_blank" href=http://www.community.webshots.com/user/wheelininco>www.community.webshots.com/user/wheelininco</a>
    " Wider IS Better!!!"
  3. SlyDog
    SlyDog 1/2 ton status
    Oct 23, 2000
    3,035
    Scottsdale, Arizona
    bias have stronger sidewalls and get a flat bottom when they sit so you have to drive it out which only takes a couple miles and radials have better tread life for onroad and alittle better manners too. But they are both good
    Paul a.k.a. Paulie a.k.a. Juan Valdez, take your pick ! [​IMG]
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    They handle quite differently and having a mixture of types on a vehicle will make it feel pretty squirrely going down the highway. [​IMG]
  5. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    It is especially important not to mix them on the same axle.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  6. MudNurI
    MudNurI 1/2 ton status
    Jul 15, 2001
    2,113
    VT
    Just curious, why would you only need to replace 2 of your tires? Am I the only one that rotates my tires with every oil change to keep the wear the same? Please don't tell me I'm wasting time.......
    1986 K5 4" skyjacker suspension 3 " body, 14 bolt rear, dana 44 front, TIRED ol 305
  7. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I have herd of this befor but did not remember untill now. I have 36" TSL bias plys but my spare is a 35" BFG. I don't ever plan on blowing out one of the TSL's but stuff happens. Would I be safe to drive it home (lets say 50mi or so)?
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
  8. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Hay xnoahx you live in SoCal too. If you are replacing your 36's would you mind giving me one of your warn down ones? Than I would not have to worry about having a 35" radial as a spare.
  9. xnoahx
    Oct 12, 2000
    817
    Ventura, CA 93004
    i already have two old 36" swampers laying around but the tread on them is just about gone. Im talking almost slicks. but if you want one its yours. Im not exactly sure when im going to replace my two tires that are almost done because i dont have the money right now. And the reason that im only replacing two is because i already replaced two and i couldnt afford the $700 for all 4 at once
    Check out my 73 K5 members.theglobe.com/xnoahx/73k5.htm
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I would not mix them. Very bad idea, although radials are best for the road.
    Tim
  11. white_knight
    white_knight 1/2 ton status
    Feb 23, 2001
    1,171
    Calgary, Alberta,Canada
    It is not recommended to mix them but...
    I drive a Class A motorhome.
    I've put two radials in front and the four rear tires are bias.
    I haven't really noticed any difference driving it but I intend to change the four rear ones to radials.
    <a target="_blank" href=http://www.whiteknight.scriptmania.com/>http://www.whiteknight.scriptma
    nia.com
    </a>
  12. pcorssmit
    Jan 2, 2001
    1,346
    Denver, CO
    My trailer has 7.00 x 15 Bias plys on it. I had to put on the spare, a 235/75R15 radial. Can't tell the difference, but I so still plan on fixing it.
    Pete
