Running Rich
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Mingler, Jul 17, 2002.
  1. Mingler
    Mingler Registered Member
    Nov 2, 2001
    29
    Calgary, Alberta
    Cough Cough...Gag, Wince, Weez........Eye's Watering...!!
    I've the old 305 in my 87 K5 with the throttle body two barrel.
    My Question.......Is there a way to lean it out so my eye's will quit watering when the rear window is down?? /forums/images/icons/tongue.gif
    I'm building a 383 for it and would rather not spend the money on new injectors or carb setup for the 305.
    Your help would be appreciated.
  2. trailblazer87
    trailblazer87 1/2 ton status
    Jun 11, 2002
    707
    Madera, CA
    Sounds like the O2 sensor might be bad /forums/images/icons/frown.gif , its an easy fix, just go out and buy one ($20), unscrew the old one, put anti-seize on the new one and screw it in /forums/images/icons/grin.gif, make sure the plug is tight, cause if it falls out you will get about 8mpg, not 15 /forums/images/icons/shocked.gif
