Running Rich
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Adub, Aug 12, 2003.
  1. Adub
    Adub 1/2 ton status
    Aug 16, 2002
    106
    OK
    Is there any logical reason why I would be blowing smoke out one exhaust pipe and not the other on a TBI 350?
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    yeah, if you have no exhaust crossover, ie H-pipe..then it will only blow smoke out of one side..or if your manifold to downpipe bolts are loose on one side the majority of exhaust can slip out into engine bay..mine does it..bolts are screwed up..
  3. Adub
    Adub 1/2 ton status
    Aug 16, 2002
    106
    OK
    No, what I mean is its blowing black smoke on one side, so it has to be running rich on one side. Is that even possible? Both injectors fire the same way.
  4. Confedneck
    Nov 1, 2002
    5,236
    oil burns black too... checked the oil level lately? im just thinkin if its throttle body..and you have black smoke out of only one side, you might have a dead cylinder on that side...try spraying water from a spray bottle (a couple squirts) on the exhaust manifold, one cylinder at a time..if it doesnt boil off right away..or boils slower than the majority of other cylinders..theres your problem
  5. Adub
    Adub 1/2 ton status
    Aug 16, 2002
    106
    OK
    Did a compression check last week, all cylinder 140-156 psi. I am burning oil, but I thought oil burned blue gray
  6. Confedneck
    Nov 1, 2002
    5,236
    ever see oil burn on wood? burns black, lots of smoke..so im guessing oil can burn black..and just because compression checks out ok doesnt mean you dont have a dead wire or plug on one cylinder, it just means that the rings and cylinder are in good shape..
  7. Adub
    Adub 1/2 ton status
    Aug 16, 2002
    106
    OK
    It doesn't have a dead cylinder. No miss, no fouled plugs, runs strong, just blows some smoke. So blowing blue and black smoke at the same time could be oil?
  8. Confedneck
    Nov 1, 2002
    5,236
    how many miles on that motor? its possible it has a smoking issue...are the plugs wet with oil at all??
  9. Adub
    Adub 1/2 ton status
    Aug 16, 2002
    106
    OK
    Yeah its got an oil issue, 140k on the bottom end, cylinder heads are new, replaced about 5k ago. #3 & #5 both burn oil and wet down the plugs. I do run hotter plugs in those cylinders to make them last a bit longer.
