Running Sand Any Precautions? Advice?
Discussion in 'The Garage' started by BowtieBlazer, Apr 5, 2002.
  1. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    I have never done a trail run before on a beach front. Any advice while driving in sand? Is speed the key? Paw print? Things to spray off ASAP to keep from ruining?
  2. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    run your tires down to 10-15 psi, it will make a worlds of difference. also i always greased all ujoint, tierods, ball joints afterward.
  3. Ryan B.
    Jul 18, 2001
    5,693
    CA
    If you got 15" rims like me i like to take em down to about 8 PSI and get a nice bulge in the sidewall.
    It makes a greater contact area.. and gives you more floatation. and floatation is what your after on the sand.
    If you keep em at street pressure you'll just dig your truck down to the axles.
    AIR IT DOWN!
    with 16's or 16.5's i wouldn't go below double digit #'s i think.
    Mash that gas pedal and have fun man!
    Hose off your exhaust asap... along with any chrome.... and don't play in the ocean salt water no matter how tempting it is. Very good way to rust out your truck. /forums/images/icons/wink.gif
  4. BowtieBlazer
    Jul 15, 2001
    2,462
    Damn! Hehe....I was planning on letting all the fords I am going with [9 broncos and a blazer /forums/images/icons/smile.gif ] run the ocean and just sit back and watch. I think I know better than to forge the ocean...especially after all the seal changing I have done this weel.
    I have 10 inch rims and running weenie 31 10.50's how low can I go without worry of losing the bead?
  5. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    With 31's you can go down in the 5-8 psi range, but keep 8 as your bare minimum, especially with a manual. Try not to shift gears too much, especially at lower speeds. Momentum is key - lose momentum and you start digging in, and seconds later you're hosed. Also make sure to hose off the entire undercarriage when you get home - make sure to also drown the bottomside of the body to get all that residual salt out.
  6. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    Are you going to Pismo? I live 15min away and go there about 2-3 times a week. Willing to show ya around if ya like, If you are going to pismo that is. With my old 32's I liked to run the front tires at 15psi and the back at 10psi, that way the truck still "floats" but you can still get $h!tty in the turns. I run my 35's at 10psi on the front and 7psi in the rear. If you do roll a bead, we can get you going again in no time. A good rule of thumb when driving through the dunes is to never stop with your truck facing uphill, and don't haul @$$ going inland.
  7. Blazinaire
    Mar 17, 2002
    1,262
    Santa Maria, CA
    OOPS! just read your profile, guess you aren't talkin about Pismo.
  8. BowtieBlazer
    Jul 15, 2001
    2,462
    Not Pismo but i appreciate the offer!
  9. Klef72K5
    Klef72K5 1/2 ton status
    Apr 8, 2001
    249
    Columbia City, Indiana
    Alot depends on the kind of tire your running. I have BFG Mudders. They have a stiff side wall. On my Jeep and in soft sand I'll run around 8 psi. On the hard sand I'll run 10-15 psi.
    I never grease anything until after I'm back home and away from the sand. If you grease before you go it just gives something for the sand to stick to.
  10. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i run the sand a lot and i always air down to 8-10lbs keep your speed up and float across the sand /forums/images/icons/smile.gif
  11. NoRulz
    NoRulz 1/2 ton status
    Feb 6, 2001
    388
    Mesa, AZ
    put a pair of panty hose over the air intake... they're a great added defense against sucking sand into the engine. If you have a stock air cleaner, just slip a pair over the snorkle, or if it's open element, figure out a way to wrap them around.
    Driving wise, momentum is your friend, so is flotation. As far as how low you can go without popping a bead, that mostly depends on vehicle weight & your driving style but what was said before about 8-10psi will give you a good footprint, but still have enough pressure to hold the bead except in a real nasty hit.
