runs nice, then dies, ignition question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fright89, May 17, 2002.
  1. fright89
    fright89 1/2 ton status
    Sep 27, 2001
    279
    boston
    Just had the truck tuned up and it was running great. Now it only runs for about 4 mimites and stalls.
    Its an 89 350 TBI. I have a post up in the garage " I HATE WHEN MY TRUCK RUNS GOOD" and a couple of people suggested the HEI module which I did tonight but that did not help. I also replaced the fuel filter. Any thoughts would be helpful.
    Maybe time for a rebuild kit for Malory Fuel pump, if they make them. If this one is croaking I'm not shore if I will get another Malory its only about a year old and was kinda expensive.
  2. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Are we talking 4 minutes all the time, or only after its cooled off. We could narrow things down here if we knew that. If it was doing around the time the engine warms up, then we could deduce that something is going funny when it goes into open loop mode (takes reading and adjusts to the sensors output). If that was the case, then the computer could be getting some bad info. Are you getting any check engine codes? Find the diagnostic plug just below the release for the parking brake. With the igntion off, take a paper clip or piece of wire and jump to two ports in the upper bank on the right side. Then turn your ignition on (don't start it) and watch the check engine light. It should blink once, pause, then blink twice, that means "12", that is normal, it will do this three times. After this, it will give what trouble codes you have stored.
  3. fright89
    Sep 27, 2001
    279
    boston
    any time cold or hot. I do have a code reader its kinda cheep. Could it give a code even if the engin light is not on?
