Rust bullet?
Discussion in 'The Garage' started by Mastiff, Jan 9, 2005.
  1. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Anyone ever used this stuff? It's competition for POR-15:
    http://www.rustbullet.com/
    I have no complaints about POR-15, but you might be able to spray this stuff without killing yourself, which might come in handy sometimes. It also claims to require less fancy prep than POR-15 which requires very good pre-cleaning. Oh, and it doesn't decompose in the sun.
  2. 85burbanator
    85burbanator 1/2 ton status
    Feb 10, 2003
    577
    lake orion, mi
  3. Sidepipes
    Sidepipes 1/2 ton status
    Nov 9, 2002
    139
    St. Thomas, Ontario, Canada
    Used it on the frame and suspension of my 78 vette that I'm restoring. I liked the fact requires little to no prep- when compared with the proper method of applying POR15. I top coated the frame with a satin black, and it turned out much nicer than POR15's satin black.... plus its just a spray bomb away to repair any scratches.
    It seems to be very tough and does stop rust from propogating.... but the car isn't on the road yet so its true toughness is unkown to me.
    I sprayed the frame with my cheapo HVLP gun and it sprayed nice- 2 coats was not quite 1 quart for the vette frame. I wore a respirator as it is overpowering like POR15.
  4. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    I looked in more detail at the info on their site and it looks pretty good. I think I'll give it a try since my left over POR-15 is probably stale anyway. One place on the site said that it'll pentrate through most paints, which I thought was interesting. So if you had some surface rust on or near/on a painted surface, you might be able to just spray RB all over and it won't just fall off the painted part.
  5. Sidepipes
    Nov 9, 2002
    139
    It can tend to lift it at the start point of the paint unless it is well sanded and all the old paint is well bonded to the metal.
    My birdcage had some paint lift on it... but not much.
