Rust fix advice needed (w/ pics)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Panther, Jan 4, 2002.
  1. Panther
    Panther 1/2 ton status
    Aug 31, 2000
    845
    South Jersey
    Hey everybody.
    I finally have my rust pics up on the web. I need some advice on how to fix this before I put down rhinoliner over the whole interior. I also have a rust spot on the vertical metal between the front and rear floor pans. Can I patch these holes or should I get new panels put in?
    <a target="_blank" href=http://briefcase.yahoo.com/bc/jsausman/lst?.dir=/90+K5/Interior/Rust>http://briefcase.yahoo.com/bc/jsausman/lst?.dir=/90+K5/Interior/Rust</a>
    Thanks.<P ID="edit"><FONT class="small">Edited by Panther on 01/04/02 10:47 AM.</FONT></P>
  2. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    Clicky : <a target="_blank" href=http://briefcase.yahoo.com/bc/jsausman/lst?.dir=/90+K5/Interior/Rust>http://briefcase.yahoo.com/bc/jsausman/lst?.dir=/90+K5/Interior/Rust</a>
    <font color=red>GOT MUD???</font color=red>
    My license plate reads:<font color=blue> 8 YR SUV</font color=blue>
    454/TH400/NP205 - 14BFF/D60/w/ 4.10s - 36" TSLs
  3. Panther
    Aug 31, 2000
    845
    South Jersey
    Thanks Krazie. It was originally clicky, but then I edited it which hoses the links.
    <font color=blue>Brilliance is like 4wd, it allows you to get stuck in a more remote location [​IMG]</font color=blue>
  4. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    Looks like you might want to use an air nibbler to cut out all the cancerous metal, and then tack in new pieces... Looks like its already come in all the way thru the underside of the body... that sucks...
    Cut it, patch it, Rhino line it. Done! [​IMG] Have fun with that one! [​IMG] Get some pics up of the final product!
  5. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    I agree with Dan, cut out the rusted spots and weld in new panels. My 82 was completely rusted out at both seatbelt anchors and all the way across the verticle piece. I couldnt find replacement panels so I just fabbed some out of .080 steel. Its really pretty simple. And if youre gonna Rhinoline it, it doesnt have to look real pretty.
    Also, when I did mine I doubled the steel around the seatbelt anchors for extra safety and just welded a nut on the backside to screw the seatbelt bolt into.
    <a target="_blank" href=http://www.geocities.com/outlaw613/K5.html>http://www.geocities.com/outlaw613/K5.html</a>
  6. Itali83
    Itali83 1/2 ton status
    Feb 12, 2001
    795
    Westbrook Maine
    CHeck out my pics at <a target="_blank" href=http://bens87toy.alloffroad.com>bens87toy.alloffroad.com</a> Shows you all the rust I had to deal with and what I did. My first time welding and doing this sort of project, not too shaby if you ask me. I also did the same thing for the seatbelt bolts. 1/2 lock nut, 1/8" flat bar for added strenth, all welded to the patch which was 16 guage.
    Ben 87 Jimmy
  7. Mudfreak
    Mudfreak 1/2 ton status
    Dec 16, 2000
    116
    NY
    Not as severe as mine was, I ended up cutting out the rust in the pillars and floor and fabbing myself the parts, because I couldn't find them anywhere. Good luck!
    88 K5... work in progress
  8. Topless84
    Topless84 Registered Member
    Dec 19, 2001
    25
    Michigan Detroit area
    The Driver side pillar(PT # 466743) is still available from the dealer ship. Unfortunatley the pass is not. You might want to run Pt# 466744(pass side) because sometimes gm will run parts again. If not Auto Body Specialist sell repo parts for those areas of Blazers. Good luck
    4X4 Once I got one, won't ever be with out one
