rust in brand new radiator
Discussion in 'The Garage' started by 76_Cheyenne, Jan 9, 2003.
  1. 76_Cheyenne
    76_Cheyenne 1/2 ton status
    Jan 23, 2002
    285
    Missoula, Montana
    I just put a brand new radiator in my K10 last July, and I just looked inside and noticed some rust starting to form. Is this normal? Im going to change my fluid, should I add any of that rust protection stuff. Thanks
  2. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Did you flush your entire system before install? I am thinking that a little rust is normal. I know that using distilled water is supposed to slow the build up of corrosion.
  3. A&P
    A&P Registered Member
    Dec 3, 2001
    88
    San Antonio, Texas
    Don't worry. I'm sure that it's just residual rust from not flushing the block thouroughly enough. Is it green corrosion forming on the copper, or is it orange like rust from steel?
  4. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    It is probably residual rust from your block and possibly a little new. I would just flush it like normal. Don't use distilled water as it promotes electolysis when mixed. De inonized water is the proper water to use. Pre mixed antifreeze used deionized water. I just use regular tap water and change it out every year or so.
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    None of the materials used in the construction of a radiator can rust. So any rust that you're seeing is coming from the engine block. Sounds like the block needs to be power flushed so that the gunk from it doesn't clog up the tubes in the new radiator.
