rust in spark plug threads on new rebuilt motor
Discussion in 'The Garage' started by down4thakrown, Jul 2, 2005.
  1. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    went to put in the sparkplugs on my rebuilt 350 and one side went fine but the other side i could barely start the plugs and when i did it didn't feel right tighting them. whats a good way to clean them out, they look a little dirty.
  2. sweetk30
    Nov 1, 2004
    25,545
    540
    horseheads , ny 14845
    go to the parts store. thay sell a plug thread chaser setup for both old and new sizes all in one. and the bigone also does o2 sensors.
  3. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    i'll do that, will it help with rust? they look all surface rusted. i tried some wd40 and slowly screwin the spark plug in and out
  4. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    i'll do that,how much do they run for? will checkers have it? will it help with rust? they look all surface rusted. i tried some wd40 and slowly screwin the spark plug in and out, it helped alot but one still feels boogered up.it gets tight before it bottoms out. could this cause the spark plugs to sieze in the threads after use? :mad:
  5. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    Make sure to put some hi-temp anti-seize on them when you install them and it should keep you from having future problems with them sticking in the head. :D
  6. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    already had that in mind, just hoping theres nothin fatal or could cause it to strip easier in the future :(
  7. diesel4me
    Jul 24, 2003
    17,561
    942
    Massachussetts
    chasing the treads...
    You need a thread chaser as suggested already..I'd use never-seize on the plug threads,but be sure not to get any on the porcelain or the electrodes--it will conduct the spark and ground out the plug,and cause a "dead" cylinder..!.. :crazy:
