Rust in the Floorboard!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BLUESMAN, Oct 31, 2001.
  1. BLUESMAN
    BLUESMAN 1/2 ton status
    Oct 3, 2001
    951
    Phoenix(but it\'s a dry heat...like an oven!)AZ.
    Hi All,I stripped the interior of my K/5 and found some rust!Pretty bad on the driver's side(can see thru the floor!)How do I get rid or stop it?I'd like to get some rust remover(do they make something?) and repair with fiberglass?I'm planning on rhino lining the whole interior.Help me!!!!
  2. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    Since no one else will help, try doing a search on the subject... Believe me this is super common and there is a ton of info and links to peoples web sites with pics... I did mine this summer I used a rust killer and them fabbed a repair panel and used silicone and screws.[​IMG]
    <font color=blue> I'd rather have a bottle in front of me, than a frontal lobotomy!
  3. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Eastwood company sells some rust inhibiting paint called "corroless". What you should do is get a wire wheel and clean the hell out of that bad spot. Then paint it up with that paint or some other rust inhibitive paint. Then I would definetely use metal. Something like a piece of galvanized that was painted and pop riveted would do well. I went with plain sheet metal and welded in place because I'm a welding nut and galavnized doesn't seem to hold a finish to well, (bare galvinized does resist rust alot better though)
    <a target="_blank" href=http://www.geocities.com/bigkern76>http://www.geocities.com/bigkern76</a>
  4. Itali83
    Itali83 1/2 ton status
    Feb 12, 2001
    795
    Westbrook Maine
    Wanna do it right, cut it out and weld in new thicker metal, wanna just get by, then you can clean up rust, patch right over it and lay the undercoating to it to slow the rust down.
    Hope this helps. If you want to see what I just did for rust work, check out my website and you'll see how much rust I had to deal with.
    ben 87 Jimmy
    <font color=blue>Rust=Bad</font color=blue>
    <a target="_blank" href=http://www.bens87toy.alloffroad.com>www.bens87toy.alloffroad.com</a>
  5. White Knight
    White Knight 1/2 ton status
    889
    Ft Worth,Texas
    In the mean time treat all the rust witha phosporic acid treament it will check the rust and chemically change the rust into a paintable surface, it'll buble a little then turn black.
    Still a very pissed-off
    White Knight
  6. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    POR15 has a system for repairing this. I agree the welding in a patch panel is a much better idea IMO.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  7. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    I use the corroless from the Eastwood company on my Chevelle and the bed of my K5. You can paint it on with a brush or thin it out and spray it on with a gun. It can also be wet sanded. There web site is www.paddockparts.com
    My K5 has a bad rust problem too. I was lucky enough to fine someone with a K5 that needed to be hauled away. I didn't charge them anything to take it off there hands.
