Rust inside axle tubes! How big a concern?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by djohnsn, Aug 19, 2002.
  1. djohnsn
    djohnsn 1/2 ton status
    327
    Plano, Texas
    I recently flushed out the 14-bolt that I was planning to use and discovered flakes of rusty metal from inside the axle tubes. The gears look ok, but the axles are pitted fairly heavily. I flushed out what seems like a lot a metal - possibly 1/4 cup's worth. Am I worrying too much or should I look for another 14-bolt?
  2. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    yikes, tough call. I would say that they are probably OK strength-wise but if you dont do a hell of a job cleaning the crap out, it will probably end up in your bearings or gears and then you know what happens next
    was this axle sitting for a long time or what? rust rarely makes its way inside the axle housing
    mike
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    Get the ball-type hone and stick it in the tubes to clean up the rust. Find a way to fasten the ball hone to a long extension to hook up to the drill and get the inside of the tubes shiny. /forums/images/icons/wink.gif
