rust on my 72
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by blazokon, Dec 5, 2003.
  1. blazokon
    blazokon Registered Member
    Dec 5, 2003
    5
    los gatos ca
    i have a ton of rust on the outer cab floor. outrigger cab support is basically gone. also the inner and outer rocker pannels. what is my best option? should i get new stuff and weld it? /forums/images/graemlins/1zhelp.gif
  2. earl87gta
    earl87gta 1/2 ton status
    Apr 6, 2003
    551
    Chuckey TN
    Look two post up in the cancer help post and it will have most of your answers but in short get ready for a lot of cutting and replacing with new steel. you will have to decide stock or not if you are planing on rock sliders build them inplace of the roker boxes.
    Earl
  3. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    I found a K5 that had very little rust (so cal truck) so I consider myself very lucky, not sure what all the parts and time add up too, but I would think finding a cleaner K5 would be cheaper in the long run. /forums/images/graemlins/usaflag.gif
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    find a clean truck if at all possible, save yourself alot of work and cash and trouble
    buying rust is bad way to go, try to avoid if at all possible, i know there are clean trucks in cali, you should be able to find a bunch there, i cant believe one with as much rust as you are describing exists there, but maybe it is possible, maybe the truck is not from cali originally, hmm.
    good luck
  5. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    My truck has been in CA all it's life. It has a fair ammount of rust and has rusted through in a few places.
  6. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Don't listen to what anybody says about getting rid of it and finding a cleaner one. Fix it! You'll feel better doing it and also knowing you saved another K5 from possible demise! /forums/images/graemlins/thumb.gif It may be more expensive and harder but it will also be a great learning experience.
  7. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    Hi,
    Another great new member! 1st Post.....already paid for a membership.....and another 1st Gen guy from the Bay Area!
    Welcome. /forums/images/graemlins/thumb.gif
    You'll find that there are a substantial amount of "local" guys around here that can help you out (and quite a few with 1st Gen K5s too)
  8. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Sometimes your money ahead to find a body with little or no rust and replace the rusted out one.
  9. mudslinger97116
    mudslinger97116 1/2 ton status
    Mar 13, 2003
    315
    F.G.OREGON
    if you feel comfortable with the body work i would go for it.your probably like me and got a killer deal on a rusted out one that in the long run you maybe money ahead.also by doing it yourself you'll create a bond with your k5 /forums/images/graemlins/grin.gifthis forum and your local one will help it go smoothly. welcome to ck5 /forums/images/graemlins/thumb.gif
  10. earl87gta
    Apr 6, 2003
    551
    Chuckey TN
    The thing with 1st gen K5 is that every part can be replaced except one the wind shield frame no one reproduces them yet but some have used a truck frame to make a new one with but I have never seen it done my self I have an extra one at the house that is going to go in to my blazer as soon as I get every thing else done in the mean time I’ve offered to let Wes send it out to try and have it reproduced the problem is it may be a while before I get it back but if they can make them I know a lot of K5 that will be saved from the salvage yards. when I started to redo the inside of mine I bought a long wheel base 75 chevy bed to use for the interior sheet metal with plans on making it look original but as my plans changed I sold it and used 14G diamond plate steel instead I found a rust free 68 that had been striped of every thing except the body and it gave me my fenders hood and doors and a friend used the cab to save on time and money on his 68. The only reason I am going threw so much is because it is a K5 and I looked for a while to find one that was in better shape but no luck Here on the east coast you just cant find them any more. I even thought a bought buying a fiber glass cab and short box and make it in to a k5 but decided to just redo the original steel lucky for me the only body work I had to do on the exterior was one fender and some small dents other then the windshield frame witch took almost a year to find a good one I could use.
  11. blazokon
    Dec 5, 2003
    5
    los gatos ca
    where to go for sheet metal and foor pans for 1st gen k5
    thanks for the support guys. i paid only 1000 for the blazer. it came with 2 fenders, 2 quater panels, and also 2 doors. did i get rippped off or was it a ok deal. /forums/images/graemlins/k5.gif
    i got a ton of rust as i stated. thanks for the site greg72.
  12. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    Re: where to go for sheet metal and foor pans for 1st gen k5
    .....I just work here. /forums/images/graemlins/grin.gif
  13. Robin
    Robin 1/2 ton status
    Oct 30, 2001
    184
    Georgetown, Texas
    You can check out my posts.
    Robin's Cancer Repair
    I've just gone through this... Can't say that it was fun, but for the most part, a 30yr old Blazer will have rust. Think of it as a "save-a-blazer" cause. It can be the charitable deed you do this winter...
  14. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    i can show you some pics of blazers that will make u feel much better about what u have! /forums/images/graemlins/rotfl.gif i parted out 2 blazers so far becuae the bodies were just to rusted out to even bother with, with out practicly replacing the whole damn body. my pickup has some rust...cab corners are gone...inners and supports are starting ot get a little on the rougher side..but still intact...and my box area were the tailgate hinges bolt to is all gone, so i cant use a tailgate.., and of course i have uite a few dents /forums/images/graemlins/thumb.gif but other than that its pretty solid, and i dont even worry about it. may not be pretty, but most fo the time it runs great and is a really fun truck to drive.
