Rust prevention
Discussion in 'The Garage' started by Mastiff, Jul 18, 2003.
  1. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    I decided not to hijack the thread about the frame-up restoration...
    What is the best way to protect the underside of the truck and treat some very minor rust that's starting? I'm in the "salt zone" here in Iowa and I want to get ahead of this before it becomes a problem. I had the factory undercoating, but it's half gone by now.
    Are ny of the commercial, Ziebart type things any good? People seem to like POR-15, but what a lot of work that would be to lay on my back and brush that all over the place. And how would it work with bits of rubberized undercoat still on there?
    Any other good options? I used to get under there and spray around with Rustoleum every year or two, but that's really not cutting it it doesn't seem.
  2. GM Man
    GM Man 1/2 ton status
    Jan 12, 2003
    549
    Denver CO
    I just put some POR-15 on my Jimmy that had some rusty spots and so far its doing good. Just my .02$
  3. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    Zeibart is an excellent parafin based rust preventative... my forest service truck service body has been sprayed in it and over the years when I lived east I had a number of trucks sprayed with it...
    BUT
    the installer has to be experienced and not just a squirt here and there.. it involves drilling numerous holes in areas that are sealed and injecting the stuff,,, while being knowledgable enough not to block drain holes etc...
    HOWEVER
    in your case its not applicable and would only be warrantied in a new vehicle without rust..
    it doesnt go well over old undercoat
    I think as the other post said por15/painting is the way to go unless you are ready for a frame off restoration
    my four cents
    cam
  4. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Anyone tried spraying the POR-15 instead of brushing?
  5. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    I just Painted my frame with por 15 and it came out great.I brushed the 15 and sprayed the Blackcote.A lot of work but it is worth it.Be careful to spray or brush in an well ventilated area,The fumes are really bad.
  6. COLLISION
    COLLISION 1/2 ton status
    May 15, 2002
    175
    Kelowna,British Columbia
    Sprayed my frame with por, works nice uses more product though.
  7. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    I put POR-15 selectively on my frame, axles and underbody this weekend. I just put the POR on creases and places that were already starting to rust a little, the rest I hit with gloss back rustoleum. We'll see how it holds up this winter. /forums/images/graemlins/thinking.gif
  8. Grim-Reaper
    7,385
    Atlanta
    Well most of the problems with rust on these trucks is GM didn't do any rust proofing where it was needed. These trucks rust from the inside out because there wasn't even paint in placs like inside the rockers till around 87 when they started with the Galvanizing (then the paint fell off)
    The problem now is if rust is forming in those areas then stuff like Zibart is not going to work. POR15 might if you can get it into those areas. Eastwood has some rust proofing tools and you might beable to use those with the POR15 to get those areas treated.
  9. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    best way i found was have a oil leak like at the pinoin seals or at the slip yoke so the oil gets slinged around everyware in that vicinity and wah-lah instant rustproofing, i also heard of guys after their oil change, taking the old oil and puttin it in a spray gun and spraying the whole under side of it, thus, oil will keep the metal wet and free of rust. /forums/images/graemlins/thumb.gif
  10. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    I've heard of that too. What a mess though! /forums/images/graemlins/grin.gif
  11. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    I solved my rusting rocker problem, I cut them out /forums/images/graemlins/thumb.gif
  12. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    my truck is suprisingly good rust wise on the floors and stuff for being around here...i just took the carpet out and plan on some rhino liner..and my undercoating is coming off the floors on the bottom too..so ill probobly just por-15 everything under there! and wash it a LOT in the winter!! all though my cab corners are gone and my rockers are starting to get a little rotted. but they are still solid for the most part.
  13. rugger03
    rugger03 1/2 ton status
    May 14, 2000
    829
    around
    You should acctually use a fresh air breathing setup when using any POR15 product it has alot of isocynides in it which can cause nerve damage, permanant lung damage, and of course death. Spraying it makes it even worse.
  14. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    ....as all of us think back to when we used the stuff... /forums/images/graemlins/ignore.gif
  15. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    whasdacha talking about? *Twitch*
    *twitch* /forums/images/graemlins/rotfl.gif
  16. dyeager535
    26,982
    191
    If you don't care about drilling a few new holes, taking a pair of semi-truck mud flaps, and hanging them from the front and rear of the wheel well opening (inside) will prevent mud and water from being slung up into the rockers and bed supports, etc. It really doesn't need to hang down below the lower edge of the body (so you won't notice it really) as long as you aren't lifted, since the middle of the axle isn't too far below that point, which is where the stuff is kicked off.
    Look inside the wheel well front and rear, and you'll see how GM did nothing to protect that area from tire "debris". You won't prevent all of it, but if you can keep it from piling up, you can keep it from being insulated...if it stays wet (and salty back east) you'll get rust. Dirt and what not provides the insulation.
    I've done this "mod" to the front of the rear wheelwell on my truck (to keep the cab supports/rockers from rotting out) and it works REALLY well, but I'm not drilling holes to hang the rear piece, although it's pretty obvious how much garbage ends up on the underside of the truck because there is no shield there. If you pull off the rear bumper "filler" panel (between the bumper and tailgate) and take a drive through mud, you'll see mud across the top of the rear bumper in two obvious tracks that corresponds to the tires. With that plate in place, it's still being thrown up under there, you just can't see it as easily.
