RUST Problems =(
Discussion in 'The Garage' started by swampblazer, Jun 27, 2003.
  1. swampblazer
    swampblazer Registered Member
    Mar 31, 2003
    49
    mass, u.s.
    on my 88 k-5 i resently removed the entire interior as for the need of a redo. well i pulled the rear carpet and found that the body mounts just above the rear axle are rotted completely out and the rears are on their way. i was considering cutting all the rear floor out and welding in plate steel. is this an ok solution to build off of stucturally?
    thanx
  2. Greenie
    Greenie Registered Member
    May 11, 2003
    28
    Glendale Arizona
    Go to LMC truck get a catalog and get the right parts to fix it. I got the floor pan and some other panels.
  3. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    If you are talking about the crossmember that the body mounts bolt to being rotted out welcome to the club. Unfortunatly I have not found any place that sells one. The factory discontinued them for my 79 K5 back in 86. I had to weld a piece of 4" channel in to use as a crossmember but if it's just the holes that are roted you can weld a steel plate in and burn a hole in it for the bushing. http://community.webshots.com/photo/77458120/77458716uwHiBs
  4. swampblazer
    Mar 31, 2003
    49
    mass, u.s.
    yeah the crossmember is rotted completely out as well as the floor pan. today i got a lucky find and bought a brand new GM replacement one piece rear floor pan from the tailgate to the front step. i just need to make some sort of crossmember
    thanx!
    luke
  5. tRustyK5
    Jul 23, 2000
    36,166
    1,363
    E-town baby!
    If you're talking about the tailpan at the rear LMC truck sells that for about a yard and a half...
    Rene
  6. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    that's why mine is a little pick-up now.my 79 was so rotted out that i could open the drivers door and STAND behind the steering wheel. /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  7. swampblazer
    Mar 31, 2003
    49
    mass, u.s.
    i hate rust,
    but i got the hole rear floor pan replacement gm with all the braces and brackets. so it should be alright. its from the tailgate to the back of the front seats. all one piece. i just need to make a set of body mount braces for above the axle!
    luke
