Rust repair
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by slimlynn1, May 15, 2003.
  1. slimlynn1
    slimlynn1 1/2 ton status
    Apr 9, 2003
    336
    Hamden, CT
    Should I buy or fabricate inner cab corners? If I should buy them where is a good place to buy them, and how well do they fit?
  2. OneInTheSun
    OneInTheSun 1/2 ton status
    160
    Pittsburgh, PA
    A friend had some decent gauge sheet metal laying around, so we just fabbed 'em up ourselves. The carpet's over it, so no need to be too fancy.
    I'd assume LMC would have them. Can anyone confirm that?
  3. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    LMC has panels to do the whole floor from front to rear...that looks like behind the drivers seat to the wheelwell. If looks aren't a problem fabricate it as the panels aren't cheap since the go across the whole bed side to side in the front.
  4. Greenie
    Greenie Registered Member
    May 11, 2003
    28
    Glendale Arizona
    I had the same problem, not as bad, but had a shop that specialized in rustoration of old cars. I live in AZ now, but lived in NJ. I know rust.
  5. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    order the part from LMC!!!
    its worth it.
    ijust replaced my floor board and actually i just finished last night. well worth it to go ahead and buy the piece, its under 100$ i believe
  6. gravdigr
    Apr 15, 2003
    1,129
    Tyrone, PA
    he would need the front bedpan and the drivers side floorpan rear which look to be about 160$ total. If you want a good look I'd go that route, if this is a beater I'd still tin it.
  7. slimlynn1
    Apr 9, 2003
    336
    Hamden, CT
    Well I decided to try fabricating the panels. I welded the first two in so far. Don't laugh I am just learning to weld. Here is what I have so far.
  8. gravdigr
    Apr 15, 2003
    1,129
    Tyrone, PA
    I wouldn't laugh if you are a beginning welder those are some nice beads. /forums/images/graemlins/thumb.gif
  9. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Thats exactly what I need to do on mine. What guage metal are you using so I can go pick some up when I get around to fixing it.
  10. slimlynn1
    Apr 9, 2003
    336
    Hamden, CT
    I'm using 18 guage. I have a brake in the basement that I borrowed from work. Now I think we need a pipe bender at work, what do you think? We already have a Millermatic 175. The next piece will be the tough one. At the bottom there is a rounded bend. A piece of 2" pipe auta make a nice radius don't ya think? I finally got some time to work on the Blazer. The wife is away for a dog show with my daughter untill Sunday. The keg in the basement will come in handy.
    Later
