Rust Sealent
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MudFrog, May 23, 2000.
  1. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    If you have rust spots that aren't very deep in the metal, and you sand them down, is there a sealent that needs to be applied to keep the rust from coming back or will only primer do the trick? This is on the body, not undercarriage.... although if ya'll know of any undercarriage sealent or heavy duty undercarriage protectant (other than spray paint ;-) ) I'd greatly appreciate ya'll sharing with me ;)
  2. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    Naval Jelly used to be some good stuff for eating rust away....and there are some acids good as well. There is more chemicals available today to completely remove rust prior to primering...
    <font color=green>[​IMG]Eagle86K5[​IMG]<font color=red>
    Masonry...It's a Good Thing
    2B1ASK1
  3. 73Jimmy
    73Jimmy Registered Member
    Mar 7, 2000
    31
    Idaho
    Mudfrog,
    Check out these guys:
    http://www.por15.com/index.html
    A couple of $10.00 starter kits did my floorboards
    and a few other spots in my back inside corners.
    73Jimmy
  4. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    Thanks for the help. I'm looking into them.
