  1. coopertwpk
    coopertwpk 1/2 ton status
    Mar 18, 2000
    478
    Spring Valley Lake Ca.
    Am I the only person in the world that gets a mouth full of dirt once a month getiing under my blazer and pressure washing everything ?I have to work on it so I want it clean Ive found small cracks here and there because I keep it clean,Just wondering .My buddy says he's never seen a cleaner NP208.
  2. James90
    James90 1/2 ton status
    May 18, 2000
    986
    Rocky Mount NC
    I try to keep mine clean it is an endless battel.
    I dont know about the cracks. you know it might be too clean I thank it is a law that a blazer has smoe mud on it.[​IMG]
    [​IMG]Go prepared
    </font color=red>90 k5 soon to be big, bad, and mean
  3. Corey-88K5
    Corey-88K5 1/2 ton status
    720
    Home: Michigan, Stationed: Hill AFB (Home of Moab.
    I got tired of spending $20+ at the car wash after wheeling. I went out and bought a 1900psi washer from Sears. (I strongly suggest not getting one from them. You are paying for the name. Get one from Lowes or something like that...) I also usually jack up the truck on stands, take off the wheels & get the brakes cleaned out. Perfect time to rotate those tires! If I don't do that, I atleast use my ramps. I love my baby when she has a clean bottom! Don't for get those holes in the very back, directly under the tail lights, and the little drain holes in the wheel wells. If you spray water in there until it comes out clean you are gettin pretty good. Plus I usually get the top of the gas tank, & the little opening that run under the floor board. They are all along the back. I like to get up in side where the fuel tank filler hose is also. Lots of little places. Lay under the truck and get the inside of the frame rails & the inside of the body under the door areas. I can go on and on an on . . .
    Corey
    88K5
    [​IMG]<font color=red>Girls Like Guys In Bow Ties
    http://www.geocities.com/corey_perez
  4. coopertwpk
    Mar 18, 2000
    478
    See im not the only one that tracks my dirty wet boots in the house dear.
  5. Steve_87K5
    Steve_87K5 1/2 ton status
    May 26, 2000
    521
    central NC
    I guess I'm not the only one who lays under the truck w/stuff dripping in my face! My '87 is starting to show some rust here and there. I carefully spot blasted with abrasive and primed and sealed, but the rust is inside a seam!!! The place that really bugs me is in the passenger door jamb, just up from the striker bolt. Rust drips out of this seam. Another place I have always kept clean, and is
    now rusting, is the rear of the cargo bed. There are holes on the underside that catch everything. I usually use LPS3 after a strong pressure wash. I can handle rust IF I can get to it!
    SteveB
