Rusted Body Mount(s)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by daleearnhardt01, Feb 8, 2004.
  1. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Alright was flexin it up yesterday and confirmed my feeling that some of the mounts would be rusted when it came time to replace mounts and do the body lift. The only one that Ive really seen so far is the front two. The metal that gets sandwiched between the rubber and attaches to the frame is rusted enough to allow the whole mount to separate allowing the front clip to go everywhere.
    Any suggestions and whatnot? I know this is a problem on these things and I hope it isnt too big of a deal.
  2. mccomas
    mccomas 1/2 ton status
    May 30, 2003
    262
    Fayetteville, NC
    i replaced all of mine with ones from LMC. it was a bit expensive (289.00) for me because i wanted to replace all of the rubber as well - the rubber cushions were the most expensive part of the kit. i had no problem removing the radiator mount or positions 3 and 4. positions 1 and 2 were a bitch because the interior mounted nuts snapped loose. i think this is where most folks were having problems. i had to cut a few access holes in the cab mount rails and go in from the side to cut off the nuts. if i would have used a torch, i could have saved hours; but the side that was dorked up was the same side that had my fuel lines and i was too chicken to use the torch. as you can see, about 20 percent of my bolts were eaten away and my rig is very clean and rust free. i was surprised as to how bad they were... it took me a full day to replace the rubber, hardware and add the 1 inch body lift.
  3. B_to_C
    B_to_C 1/2 ton status Author
    Jan 15, 2003
    1,861
    In Government Housing
    I feel your pain
    /forums/images/graemlins/ignore.gif
  4. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    You mean that's not how they're supposed to look? /forums/images/graemlins/confused.gif
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
    (Okay, I'm actually not laughing...several of mine look the same) /forums/images/graemlins/doah.gif
  5. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    yeap..i have that same problem..my front two radiator support ones look just like that, bottom ones and the retianers are gone, so when i go over a big bump, the front clip slams up and down, really anoying, i got the bushings and retainters from the dealer to fix it but there still sitting in the truck /forums/images/graemlins/rotfl.gif
  6. bigburban383
    bigburban383 1/2 ton status
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    I feel your pain
    Yikes! Brings back some painful memories /forums/images/graemlins/yikes.gif
  7. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    Anybody know if these mounting "buckets" are available anywhere?
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i doubt it, id just take them from a parts rig
  9. mccomas
    May 30, 2003
    262
    Fayetteville, NC
