Rusted Bolt Help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Confederate9, Mar 13, 2001.
  1. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    I was taking out my interior spare tire carrier today so i can remove my carpet, and 1 bolt is rusted and wont budge!!!!
    i need some help!
    its the bolt on the floor board closest to the tailgate.
    ive tried pulling, kicking, pushing the wrench, and nothing. wont even move.
    any ideas on how to get this off?>
    thanks
    <A target="_blank" HREF=http://confederate9.coloradok5.com/>http://confederate9.coloradok5.com/</A>
    <font color=red>K5: Because size DOES matter</font color=red>
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    First go to the Autoparts store and get some PB Blaster. Soak it down with Blaster and then try it.
    If that doesn't work try heat(torches), but be extremely careful around the gastank or remove the gastank!!!!!!!!!!!!!!!!!!!!!!!!!
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>
  3. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I would soak it WD40 and let it set for a while, then try using a long breaker bar to get it out
    Murphy's Laws on Life :
    "Opportunity always knocks at the least opportune time." [​IMG]
  4. RESTORE89
    RESTORE89 1/2 ton status
    Jan 31, 2001
    548
    CHAS SC
    it wont be fun, but worse case scenario, grind the head off, drill out the bolt, and use an extractor. i had a corvette once that would break off bolts where the rear anti sway bar bolted to the rear end, and that was an ongoing problem, until i discovered grade 8 bolts. i was only 18 at the time, and that car was my real introduction into the world of the unqualified driveway mechanic. i still miss that old car. a 75 convertible with a 400 turbo 3 speed auto, and about 400 hp.
    chris
  5. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    After you strip the head out try a small pipewrench (6") and a piece of pipe...it will either come out or break off
    Luke
    84 K5
  6. Confederate9
    May 29, 2000
    1,686
    Greensboro NC
    i jsut pick up this stuff called "liquid wrench"
    the guy at the store said it works great.
    im suppossed to spray it on, then tap the bolt to creat a vibration, then let it sit for 15 min, do that 3 times then try to get it off, and repeat as necessary.
    lets see how it works.....
