Rusted brake bleeders...
Discussion in 'The Garage' started by Calclips, Jul 27, 2003.
  1. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    I wanted to bleed the brakes on my K20 (D44, but you knew that already) today, but the bleeders are rusted to the calipers. The bleeder itself is so rusted that it just wants to fall apart when I put a wrench to it. Is it okay to heat a brake caliper, as I was thinking that could help. Is there anything else I can do, short of getting new calipers?
    Thanks a lot,
    Dan
  2. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    I say no, just because I'm pretty sure brake fluid is flamable. I'd just spend the extra cash and buy new calipers, if things are that rusty it might be time to replace them anyways. /forums/images/graemlins/smirk.gif
  3. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    try soaking them in blaster and using vice grips?
  4. Calclips
    Apr 4, 2001
    1,005
    I kinda agree with that dude whos nutz about trucks... if I'm gonna have to take them off I'll probably try and pick up some used calipers that are in better condition. I was hoping that somebody was gonna tell me it was okay to put heat on the calipers... because I didn't think it sounded like a good idea.
  5. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    The heat fries the seals inside/forums/images/graemlins/eek.gif Calipers are about $25 each at most parts places, certainly not worth messing with.
    Rene
  6. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    I've done it a few times with "alittle" heat. Haven't lost the seals, BUT I'm fully aware this could happen if it got too warm. My best too for stuck bleeders is a deep six point socket that fits the bleeder screw, stuck on one of those impact drivers (the type you hit with a hammer). Some penitrant and a few taps with the driver usually works. If not some mild heat, some crossed fingers, and alittle harder whacks. /forums/images/graemlins/wink.gif
  7. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Hmm..
    Autozone calipers are $15. Whenever I strip/break a bleeder screw or have caliper problems, I just go get a new one. I tried rebuilding one once.....Never again. Not worth the time and effort required, when you can get a new one as cheap as they are.
  8. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    I am having the same problem in the back. Unfortunatly in order to replace the rear cylinder I need to dismantle the rear brakes...yuck. But that's not all folks, the steel line is seized to the fitting and turns with it twisting. that line is in turn seized to the rubber line block, which is seized to the steel line which goes partway down the frame and finally connects to new line. So the easy $30 cylinder replacement turns into 2 cylinders, 3 pieces of seel line and a rubber line and starts to not look so cheap /forums/images/graemlins/deal.gif
  9. fatboy
    fatboy 1/2 ton status
    Jul 1, 2003
    290
    Tennesse
    load it up with a good penitrating oil and let sit for hours and try along with the above tips /forums/images/graemlins/burb.gif there is a penitrent made by Zepp that is called corosion X. this is the best stuff I have used. it must have smurffs and all that stuff in it to make it work so well. /forums/images/graemlins/burb.gif
  10. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    i use PB blaster and heat. but the best [I love Jeeps] ive ever used is called KROIL....it was made for the govmnt for boeing. we had some sittin in a coffee can over nite and it seeped through the bottom of the can where it was crimped together....it had a small ring around it on the cement. i aint ever seen n e thing else go through such a tight space
    NITRO
  11. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    [hijack] So, if heating a caliper around the bleeder screw will damage seals, wouldn't grinding them (to fit 15" wheels) destroy the seals, etc? /forums/images/graemlins/crazy.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/ears.gif [/end hijack]
  12. Calclips
    Apr 4, 2001
    1,005
    hmmmmm... interesting point. But... don't brakes also get very hot during normal operation? I would think that heating them with a torch would get them way hotter than normal use... but grinding may not.
  13. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    I've never ground next to the bleeders before.../forums/images/graemlins/smile.gif
    Rene
  14. heavy4x4
    Aug 28, 2002
    3,270
    Oh, I didn't know there were seals right at the bleeder. I thought we were talking about the piston and all that good stuff. /forums/images/graemlins/blush.gif Thanks. /forums/images/graemlins/smile.gif
  15. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Since their already Boogered, smack em with a hammer, then try a wrench or the Dicey Visey Grip's. /forums/images/graemlins/eek.gif
  16. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    The seals are closer to the bleeder than they are to the surface ground for clearance...
    Heat em up and spin em out...what do you have to lose? If you fry the seals get new calipers. If you break the bleeder off anyways, get new calipers. If the bleeder comes out and the seals don't get wrecked you just spent a couple of hours pissing around with calipers worth no more than $15 each...
    It's your call, I personally have better things to do with my time./forums/images/graemlins/smile.gif
    Rene
