Rusted floor around seat mounts; how to fix?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fortcollinsram, Sep 9, 2002.
  1. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I am going to be fixing my truks minor rust problems in the near future...I have 2 fairly good sized (~2.5" or so)rust holes in the drivers and passenger rear cab corners...I was just going to cut out the rusted area and MIG weld in a new panel in the corners. I also have some rust that has weakend the meatal enough that it has cracked around a couple seat mounts...
    First, How are the seat mounts held onto the floor? What is the best way to replace the rusted sections around the seat mounts? Is there a good way to reinforce the seat-mount area? I am just sick of the floor flexing enough that the seats rock back and forth...
    Thanks in advance...
    Chris
  2. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    I have a gaping crack where my driver seat bolts in... as far as i know... cut the section of floor out and weld in a new piece.. either that or get two peices of scrap metal and put it on either side of the floor and reinforce it...kinda sandwiching it.
    I plan on fixing mine sometime soon... if you get yours done, let me know how it goes. Thanks!
  3. beachinblazer
    beachinblazer Registered Member
    Apr 15, 2002
    20
    my friend's neighbor and i tackled that same situation. we just got some 1/8th " steel plate about 3 inches wide by 20" long and welded it to the floor panel after using a bottle jack to life up the major cracked pieces. rides too firm now, but its better than scraping my butt on the ground
