Rusted together stuff.....
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Blazin'Grrl, Mar 28, 2000.
  1. Blazin'Grrl
    Blazin'Grrl Registered Member
    Mar 24, 2000
    54
    Indiana
    My trailor hitch is one that you can take out by pulling a pin out....well, all of the assembly has rusted together...besides just cutting the whole thing off, is there anyway to free that stuff up? I doubt it, but thought I'd ask.....
    <font color=purple>Sarah</font color=purple>
    <font color=purple>[​IMG]'83 K-5 Silverado Blazer[​IMG]</font color=purple>
  2. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
  3. Steve88
    Steve88 1/2 ton status
    526
    Sunny Arizona !
    or after that WD40 find a shipping dock afterhours and slowly back into it (so long as the hitch sticks out farther anything else!) (I guess any building would do, but I was thinking of those large steel stops that the big rigs back up into)
    <font color=red>Steve88</font color=red>[​IMG]
    88K5 Silverado
    thunderdog@metallica.com
  4. dremu
    Feb 27, 2000
    15,958
    452
    East of San Francisco
    Mix equal parts:
    1. WD40 or other lube-goo spray "panther piss" etc.
    2. Patience, and a torch if you have one
    3. BFH (big ... hammer.)
    I find particularly that the BFH, or the modern equivalent, the handheld grinder, solves many such problems ;-)
    -- A
    '74 K5 Blazer "Tank Grrl"
    '77 Chalet sans Blazer
    and more to come...
  5. Blade
    Blade Registered Member
    Feb 21, 2000
    27
    CA, USA
    Liquid Wrench has been my favorite rust penetrant.
    [​IMG] Blade
  6. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    See if you can find some stuff called Blaster
    I used it the first time on brakes, I had to replace the rear cylinders, and they were so rusty it would not budge. Sprayed on blaster ler it set a half hour(got a beer) and the stuff came right apart. It kinda eats rust.
    <font color=green>Eagle86K5[​IMG]
    <font color=red>Only guy I know that can get out of line in a one car funeral
  7. 89Jimmy
    89Jimmy 1/2 ton status
    192
    Northern N.Y. east end of Lake Ontario
    We had a similar problem on one of our "shop trucks" at work.(A beater F250) Used all kinds of penetrating lubes,heat and hammer. We decided to leave it on and rusted.
    John
  8. mudfanatic
    mudfanatic 1/2 ton status
    Feb 18, 2000
    614
    Aloha, Oregon
    why not pull the pin, wrap a tree saver around a big tree, hook a tow strap to your hitch, then hit the gas!
    '77 K5
    <font color=red>mudfanatic</font color=red>[​IMG]
  9. kim tate
    kim tate 1/2 ton status
    134
    New Orleans
    Probably doesn't need to be said, but to err on the side of caution - be careful with a torch in that area. I removed a similarly rusted receiver hitch with an eight pound hammer. Good luck.
  10. K5 NUTT
    K5 NUTT 1/2 ton status
    1,611
    Grand Junction Colorado
    GM sells there own penitrating oil...i think its as good as PB Blaster or better....and yes you might have to use the ole Blue Wrench...with some elbow grease attached to a 4lb or better hammer!!!
    AZBLAZER
    1979 K5
    1976 K5 Chalet
    1972 K10 Suburban
  11. Blazin'Grrl
    Mar 24, 2000
    54
    Indiana
    uhh....the pin is rusted in too
  12. collegeK5er
    collegeK5er Registered Member
    Feb 29, 2000
    59
    huntsville, TX
    your should be able to tap the pin out just be careful not to bend it over.
    Doin' it all on a budget
  13. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Yes I also had this delema
    and the fix was liquid wrench heavyly aplied then drove to a field backed up to the biggest tree hammered the pin out useing a bolt small enought to just fit through the hole.
    bang bang bang until the pin comes out
    now hook up the tow strap to the tree and hitch jump in and nail it!
    Be very carfull when I did this the hitch came out and flew back oh about 200ft wow I didn't expect it to fly that far but it did so watch out.
    good luck
    Burt4x4
    Rock ON!
  14. DangerB
    DangerB 1/2 ton status
    420
    Frisco, TX.
    Cool, I hope mine rusts in.
    DangerBrett[​IMG]
    <font color=blue>harder, faster, longer, stronger</font color=blue>
  15. **b**
    **b** 1/2 ton status
    279
    KIllington, VT.
    Iam w/ Mike...
    BIG HAMMER...
    smack it like a red headed
    step child...
  16. AZK5
    AZK5 1/2 ton status
    Feb 22, 2000
    448
    Chandler, AZ
    What's rust?
  17. Steve88
    526
    Sunny Arizona !
    I think it's a reddish color of bumpy paint... heh-heh
    Haven't seen it for years!
    88K5 Silverado
  18. MICHIGAN BLAZER
    MICHIGAN BLAZER 1/2 ton status
    296
    Middleville Michigan
    That's just plain mean......you guys aren't very nice or compassionate! I hope you metal starts to deteriorate and biodegrade from the sun.
    <font color=red>MICHIGAN BLAZER
    <font color=green>89 Fullsize Blazer
    87 Cherokee
    65 IH Scout
  19. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    We used a air hammer on the ones at work to brake up the rust, sometimes it took a combanation of oil and hammering it
    C'moe
    <font color=black>the blazer is "Back in Black"
  20. AZK5
    AZK5 1/2 ton status
    Feb 22, 2000
    448
    Chandler, AZ
    Actually the sun takes the paint off our trucks.
    CB
