Rustoleum rust reformer
Discussion in 'The Garage' started by Mastiff, Sep 21, 2005.
  1. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Anyone used this stuff in the spray can? I know it can't be as durable as POR-15 or Rust Bullet, but being able to spray it is a huge plus. If it's decent, I'd consider hosing it all over the underbody and frame to maybe stop the rust and then hit it with regular spray paint. POR-15 is torture to paint with while laying on your back under a vehicle - gets on you, is permanent if it gets on the ground, etc. Plus it doesn't seem good to glue bolts down with it - but I've got no problem spray painting over all my bolt heads/threads, brake lines, etc...
    Anyway, if anyone has any experience with the stuff, I'd be real curious to hear.
  2. diesel4me
    Jul 24, 2003
    17,537
    923
    Massachussetts
    it helps,but...
    I've used them all--Morton's "Rust-Mort",Permatex-Duro "Extend"."Neutra Rust", "Rust Reformer"--all basically the same thing--the "Rust Mort" is a liquid,can be sprayed in a paint gun--its Phosphoric acid basically..the others are a milky looking latex based stuff that turns clear and the rust into black primer looking stuff that retards further rusting--.
    ALL of them need to be topcoated with another paint...they are temporary at best..it will slow down the spread of rust,but not stop it entirely!..I think POR-15 is worth the hasssle,though even that sometimes does not hold up well under lots of salt and sun exposure where I live..I think its kind of expensive--black gloss rustoleum or a good polyureathene auto paint seems to do just as good for me..haven't tried "Rust Bullet" yet, it might be better,or the same as POR-15 --I think drain oil sprayed on the chassis works best around here--especially if you use oil drained from a diesel with lots of soot in it--seems to stay on longer.. :crazy:
  3. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    I have used the stuff out of Eastwood catalog. Brush on and in spray can's. Just take off loose rust with wire wheel/brush and apply. Has stood up for 3 years so far. Have also used stuff called "Zero-Rust" comes in cans, or in gallon for spray guns. It works pretty good. A couple buddy's of mine painted the'r cars (65 El Camino, 58 Plymouth) with the stuff. Comes in basic colors...red, blue, yellow, green, white, and black. Has a satin finish. Works pretty good.
  4. wazzabie
    wazzabie 1/2 ton status Premium Member
    Apr 17, 2001
    1,719
    5
    Washington State
    I like the brush on stuff. I would think that the spray would create to many fumes.
  5. ak bandit
    ak bandit 1/2 ton status
    Sep 10, 2004
    386
    Eagle River, Alaska
    Rust Bullet can be applied with a paint gun. But I'd buy a cheapo just for the Rust Bullet. Although, that stuff is so expensive I wouldnt even want to waste the overspray! I've heard that Rust Bullet is some pretty awesome stuff. Only drawback is it's silver...
  6. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    RB and POR-15 fumes are deadly. You'd need a respirator and a full suit because the atomized stuff would glue itself to any exposed skin.
  7. ak bandit
    Sep 10, 2004
    386
    Eagle River, Alaska
    Definitely need a respirator. I had a buddy spray on his Rust Bullet. He just wore gloves and long sleeves.
