Rustoleum
Discussion in 'The Body Shop' started by bigcountryk5, Jun 26, 2005.
  1. bigcountryk5
    bigcountryk5 1/2 ton status
    Mar 13, 2004
    931
    G-vegas(Greenville) South Carolina
    well i found a paint color i like it's Rustoleum Smoke Grey. It looks similar to Gunmetal grey and i think if i get it i'll be pleased, but it says on the gallon that it is an oil-based enamel so............
    1. this is gonna be a trail rig not looking for showcar paintjob it'll be my first and being a trail rig i just want tough paint and a uniforme color
    2. is there a reason i should not use this paint will it not hold up well being oil-based
    3. I know Squat! when it comes to paint any hell would be appreciated :cool1:
  2. sledheadak
    sledheadak 1/2 ton status GMOTM Winner
    Apr 29, 2005
    1,283
    anchorage,alaska
    should stick fine if you prep it properly and clean the surface real well with a good wax and grease remover form a auto paint store.
  3. bigcountryk5
    Mar 13, 2004
    931
    well i should be ok then i will definately be prepping well i know that 80% of a paint job is surface prep......
    i was more curious about the paint itself though i.e. is it tough easy to work with does it do ok with UV exposure etc..... :confused:
  4. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    I know oil-base house paints usually take a while to dry, so this stuff might be the same way.
    Wear a respirator when you apply it. Not a dust mask, but a respirator with filters for organic vapors.
  5. bigcountryk5
    Mar 13, 2004
    931
    yeah i got the respirator covered and i had noticed a 24 hour dry time :confused:
  6. OLD DAWG
    OLD DAWG 1/2 ton status
    Jul 20, 2002
    444
    MONTROSE, COLORADO
    I've painted a couple of 4x4's with it and other than thinning it quite a bit it wasn't too bad. After it dries you can even wet sand out any runs/sags you might get. As to UV problems it took about 5yrs for it to oxidize.
  7. bigcountryk5
    Mar 13, 2004
    931
    sounds good i'll post up picks in a few weeks to show how it turns out :D
