Rusty 14 bff gears
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by avgas, Jul 10, 2004.
  1. avgas
    avgas 1/2 ton status
    Jun 5, 2003
    179
    Renton, WA
    ok I cracked open my free 14bff, it appears that I'm running into quite of bit of unexpected problems/ expenses.
    mostly just brake stuff, like the drums are shot, all brake hardware and wheel cylinders are toast(This was expected)
    But my problem is the actual ring gear has some rust on the gear surfaces where the gear was exposed to the air for years(the side the was in lube is fine of course). This is causing a slight amount of binding when the pinion meets those rusty gears. The rust isn't all that bad I think postly just surface rust with maybe some pitting underneath. What would you guys think of hitting each of those rusty teeth with some emery cloth/sandpaper? Do you think that would free them up enough to wear properly. I'd like to finish the work that needs to be done on this axle so maybe I can get it in next weekend.
    thanks
    -jake
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Re: Rusty 14 bff gears *DELETED*
    Post deleted by HarryH3
  3. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    If it's just light surface rust, then I'd try the emery cloth cleanup routine. But be alert to any strange sounds or rumbling from the rear end for the first 10,000 miles or so of operation. /forums/images/graemlins/wink.gif If it works, then you saved a bunch of money. If it doesn't work, then the gears needed to be replaced anyway. /forums/images/graemlins/whistling.gif
    Exactly.
    No need to spend the money if a cheap fix might work.
    I have done it before successfully.
    I sprayed it with liquid wrench and scraped off the rust after it loosesned up then I used steel wool.
    That way I didn't remove any metal but cleared up the surface.
    If you use emery cloth it might shave some of the metal and you will have some wear and noise.
  4. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,072
    483
    Grand Rapids area
    I cleaned up the teeth in my 14b s/f. The pitting was pretty minor, not accounting for much surface area in the contact region. It has worked fine for years. Make sure you don't remove any material except rust.
  5. k2-k5
    k2-k5 1/2 ton status
    Sep 30, 2003
    285
    Vancouver, WA
    I have some brake stuff should you need it.
    drums wheel cylinders backing plates etc. /forums/images/graemlins/thumb.gif
  6. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    Driving should polish them up. Change diff oil after a while.
  7. avgas
    Jun 5, 2003
    179
    Renton, WA
    really? how much do you want for it?
