Rusty 14bff gears
Discussion in 'Pacific Region' started by avgas, Jul 10, 2004.
  1. avgas
    avgas 1/2 ton status
    Jun 5, 2003
    179
    Renton, WA
    This post is also in the garage but there's so much noise up there I fear I won't get a timely response, so anyone local have any ideas?
    ok I cracked open my free 14bff, it appears that I'm running into quite of bit of unexpected problems/ expenses.
    mostly just brake stuff, like the drums are shot, all brake hardware and wheel cylinders are toast(This was expected)
    But my problem is the actual ring gear has some rust on the gear surfaces where the gear was exposed to the air for years(the side the was in lube is fine of course). This is causing a slight amount of binding when the pinion meets those rusty gears. The rust isn't all that bad I think postly just surface rust with maybe some pitting underneath. What would you guys think of hitting each of those rusty teeth with some emery cloth/sandpaper? Do you think that would free them up enough to wear properly. I'd like to finish the work that needs to be done on this axle so maybe I can get it in next weekend.
    thanks
    -jake
  2. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    Worst case is your will be replacing the gears right? So I'd say try it and check it after 500 miles. If it works you have good gears for free, if not you will have to replace them.
  3. clubba68
    clubba68 1/2 ton status
    Dec 6, 2002
    1,511
    Eugene-Portland, Oregon
    I think you could probably hit them with some Brakleen too. I don't think that would mess anything up. I'm sure someone will correct me if it will. /forums/images/graemlins/thumb.gif
  4. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    ya man just clean them up as best as u can....you will get a few hundred miles at the least on them before they go poopy anyways...if they are gonna... /forums/images/graemlins/waytogo.gif
  5. avgas
    Jun 5, 2003
    179
    Renton, WA
    Super, thanks guys. It's always tough working on $hit by myself and not having a little input. I'm one of those do it right the first time or don't do it at all kind of people. My blazer is a reflection of that, everything I've done work on is really tight using all the good [darn], but everything that hasn't given me trouble so far I haven't really given a [darn] about, so basically I've got a POS blazer with some really nice parts on it.
  6. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    If the gears are rusted what do the bearings look like? I would NOT run this axle with fear of spining a bearing as a result of corrosion. At least check the bearings if your going to chance running it....
  7. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    Ummm, isn't that all of our Blazers? /forums/images/graemlins/grin.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/whistling.gif
  8. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    The gears in my old 14bolt had rust on them, I cleaned it off and ran it for 2 yrs w/o a problem, then sold it and it is still on the road... no worries... just run if for a bit and then change the gear oil to get the crap out.
