rusty cylinder walls...engine builders???
Discussion in 'The Garage' started by 3car, Aug 18, 2003.
  1. 3car
    3car 1/2 ton status
    Dec 16, 2001
    976
    Hernando, Florida
    ok,heres the deal.there was this guy.he built a motor for his truck,and then wrecked the truck with 3000 miles on the new motor.he sold the motor to a friend,who didnt have any way to get it out of the wrecked truck,except to pull off the heads and lift it out manually.the motor was then stored in a shed for some time(without heads),and some light surface rust has developed on the cylinder walls.what can i do?i dont think its bad enough to need honing.will it be ok to oil up the cylinders,and spin the motor over by hand,and let the rings do the work?any suggestions?
  2. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    If it is only light rust I would spray WD40 in the cylinders then wipe them out and oil the cylinders and turn it over and look for any deep rust spots.
  3. 3car
    3car 1/2 ton status
    Dec 16, 2001
    976
    Hernando, Florida
    ttt
  4. bigblock44k5
    bigblock44k5 1/2 ton status
    Jun 8, 2003
    396
    Hurlburt Field, FL
    you could always use a scouring pad(like for dishes). It wont take any metal off and should take off the surface rust.
  5. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    I'd also keep a vacuum running and hold it in the cylinder while scrubbing it, that way the junk won't just land on the pistons and have the slightest chance of getting caught in the rings. /forums/images/graemlins/thinking.gif
