rusty rockers
Discussion in 'The Garage' started by MUD JUNKIE, Sep 28, 2002.
  1. MUD JUNKIE
    MUD JUNKIE 1/2 ton status
    Oct 24, 2001
    379
    Reddick,florida
    anyone got rusty rocker panels,or floorboards?im sure the majority of us do.how can i fix the rockers?im afrid im funna fall threw one day,and the floor is getting pretty bad.
  2. blk87K5
    blk87K5 1/2 ton status
    Dec 26, 2001
    1,290
    Lubbock, Texas
    Get some sheet metal and find a mig welder if you don't have one. Sheet metal is really easy to work with. Cut out all of the old stuff first. Tack one area, then bend, then tack a little further down, then bend a little more, etc. Cut the rocker panels out and weld in a set of sliders from Bent and Twisted. Top quality stuff. /forums/images/icons/cool.gif
  3. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    one thing i noticed tough is on the floors..wear they meet up with the rockers..the floor goes up a little bit..like it is elevated a tiny bit or something, and if i just put some regualer old sheet medal up to the trocker when i went to replace it it would slop down..
  4. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    HAHAHA. Rockers what are they? My inners are gone and I think the paint is holding what is left of the outers. /forums/images/icons/blush.gif I'm in the middle of gutting my truck now. I plan to cure my rocker problem with 3"x3" square tube. /forums/images/icons/cool.gif As for the floor I'm going to patch it back together.
  5. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    you know along wear the rockers go up to the floor the floor is elevated a little..ill have to take some pics i guess but i want to see a pic of someone that patched the floor there..i noticed my seat ..drvers side..is leaning tord the side..the left..meaning the floor is falling there...and wear the seat belts are is going to need to be fixed..and WHAT about that part wear it goes up a leval from the front to the rear cargo/seat area..what do you use to patch the corners up?
  6. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    My rockers are just starting to rust out. I can see through the inner of the left one. The right is still in good shape. Think I'll go with a set of sliders from Bent and Twisted and cure it befor it becomes a problem.
  7. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Once I get into patching everything up I am going to fab up my own panels out of galvinazed. {sp} I will try and get the front carpet out tommorrow and take pics. The lower part where the seat belt attaches is wasted on mine. When I patch everything I'm not going for looks but function and strength then I will Hurculine everything.
  8. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    yea i think im going to start gutting mine out tomorrow as well. i will take some pics to but ill have to wait till monday to get my computer back so i can loud the madness lol...
  9. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
  10. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Damn, looks like you were about ready to fall through.
  11. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    On the floor portion where you talk about it sloping down and then it turns straight down then back level. If you take 16 ga material and use straight edge like your work bench with a hammer bending just a small amount all the way across the length back and forth you can shape that slope and the bend where it meets your rocker panel. It takes some paitence though. I used to be able to watch the ground go by while driving down the road in mine. At the rear where it slopes up to the bed I bent one piece around a culvert pipe to get that upslope radius and then had to cut two or three smaller pieces where it meets the bedside to finish it up. If you get that part done and live through it then I can hook you up on the rocker portion. /forums/images/icons/grin.gif
  12. COLLISION
    COLLISION 1/2 ton status
    May 15, 2002
    175
    Kelowna,British Columbia
    Wayne you may want to check your cab mount area,looks like you might have a problem with rust at the crossmember under the rear floor right ontop of the rear mounts.
    Either way it looks like you got alot of work ahead of you. /forums/images/icons/ooo.gif
  13. ChevBlazin
    ChevBlazin 1/2 ton status
    Feb 4, 2002
    332
    St. Paul area, Minnesota
    I bought new rocker panels, cut out the old ones and welded in new ones. It was much easier thatn I expected. I cut some sheet metal to cover the back side of the rockers as it was gone also. For those corners where the floor goes up behind the seat I cut out what was left of the rusty metal and welded in new corners from some thick sheet metal. Hope some of that helps.
  14. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I might just have too order the slider and step from ya, then head to body shop. I'm not good at body work. I can turn wrenches, but I'll leave the body work too those who know what they're doing !!!! Gonna do my axles first befor anything else.
  15. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    i hate to say this..but my god, mine is worse than that by far!! lol..im not kidding..ill take some pics as soon as i can find a puter to put them up on..im going to need the whole rear section/tailpan...and new rockers, well..you see for your self..lol..im really going to need ur guys help more than ever hear! lol..COLLISION..you to! lol..
    Bryan
  16. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Problem with rust, what gave you the first clue. /forums/images/icons/grin.gif Ya you are right though. Fortunately I have a nice rust free tub that I cut from a M Blazer. I cut it right behind the front seats. Funny thing is it was patched around the seat mount holes on both sides from cracking and not rust so I cut right behind that patch work. I'm debating if I want to fix my tub or cut it off and splice the other one in. The only problem with the splice is I still have to cut my outer quarter panels off and put them on the other tub because they are fubared.
  17. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    lucky...man i would LOVE to find a nice tub...
  18. anatomiczero
    anatomiczero 1/2 ton status
    Jun 26, 2001
    418
    Washington
    My tub is rust free, I took the carpet out expecting plenty of rust but only found a little surface rust in a few spots. The rockers are good, just a small hole or 2 in the corner where it meats the quarter panel i think, nothing serious.
  19. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Yeah the was a good score considering it was free. /forums/images/icons/grin.gif I will start working on it soon. I know one thing though and that I am not putting carpet back in it. I think that is the main reason they rust. The tops leak the carpet gets wet and one thing leads to another.
  20. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    yea...all rhino liner for me... /forums/images/graemlins/thumb.gif - hey cool we got new thingys
