rusty seat help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 89k5blazr, Feb 5, 2002.
  1. 89k5blazr
    89k5blazr Registered Member
    Apr 24, 2001
    48
    The Garden State
    My 89' K5 has driver and passanger seats that are in need of a little attention... they got some decent amout of rust on the base....so my question is....has anyone else fixed this problem (repainted them i assume), and how difficult was it to do (ie: is it a sunday afternoon job or does it require a little more time)..... thanks-
    89 K5 Blazer 350 ci...2" susp. lift for BFG MT 33x12.5x15's on M/T Classic II 15x10's. My two-tone black and red baby...<P ID="edit"><FONT class="small">Edited by 89k5blazr on 02/05/02 12:39 AM.</FONT></P>
  2. rain1971
    rain1971 Registered Member
    Feb 2, 2002
    50
    canada (7 hours from seattle washington)
    The seat braces on blazers are 8 bolts to remove driver side, 4 bolts to remove passenger side, and then you can take the braces off of the seats, but if they are really rusty, be sure not to snap rusty bolts from under the seats.
    you can remove the braces from the seats themselves, then sand, primer, paint...
    hope you can understand this :)
    Theres no replacement for displacement!
    I want a big block!
  3. 89k5blazr
    Apr 24, 2001
    48
    The Garden State
    cool.....i just wasnt sure if it was a big pain in the a** to take the seats out...
  4. tRustyK5
    Jul 23, 2000
    36,170
    1,375
    E-town baby!
    The 89 seats are bolted on the pedestals with 4 bolts each. I recently removed mine and it took me less than 15 minutes to remove both front seats and pedestals. Sand the bases down, blast em with some primer and paint and you're good to go. An easy afternoon job...[​IMG]
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  5. rain1971
    Feb 2, 2002
    50
    A warning about the bolts, if they are rusty they snap easily and then you will have to drill , tap, etc...
    turns and easy job into a long one.
    if the bolt heads under the seats look rusty, use caution, spray em down with wd40 or some kind of oil.
    I want a big block!
  6. TwoCrowsDesign
    TwoCrowsDesign 1/2 ton status
    Jul 13, 2001
    387
    And to keep the moisture from coming back up to your base after you pretty everything up, put a dab of silicone caulk on the bolts when you put it all back together.
    John
