s-10 blazer tranny and a tired 305 k-5
Discussion in 'The Garage' started by chevyk5blazer666, Oct 10, 2005.
  1. chevyk5blazer666
    chevyk5blazer666 Registered Member
    Jul 6, 2005
    44
    N.J.
    ok my question is. will a manual transmission out of a 4.3 or 2.8 liter s-10 blazer fit and hold up to a tired 305 k-5 blazer? with 12 bolt axles with 4.10's and 36 tsl swampers.
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the 2.8 manual won't last and you will have a hard time bolting it up to a sbc as there are no factory bellhousings. its the T5 trany, it is weak, i blew one up behind a 2.5 2wd.
    the 4.3 MAY last, it is a NV3500 which was found behind some 88 and newer 1/2 tons. the problem is you will only beable to run a s10 transfer case as the adapter is a 5 bolt pattern instead of the 6 bolt found with the np208 or np241. with the s10 transfer case, its driverside drop only and its not that strong.
    its best to use full size parts in a full size truck.
  3. chevyk5blazer666
    Jul 6, 2005
    44
    N.J.
    yah that makes sents. it just poped in to my head ,b/c im tired of the automatic.thanx
