S-10 driveline??
Discussion in 'The Garage' started by Thumper, Nov 14, 2004.
  1. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    Ok, I have a naked frame/ driveline from the donor S-10. I want to sell off some goodies from it, but need to know what it is before I can advertise.
    Its a 92 S-10 ext cab 4x4. It had a 4.3l V6, appears to be a 700R4 tranny and a t-case and diffs. What t-case would it be? What diffs? Any idea on gearing that they might be?
    Thanks for the help!
    Mike
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    tcase is a np231, rear axle is a 7.5, front is a 7.5" IFS, and probably has 3.08 ratios
  3. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    it will bea ten bolt rear one of two different sizes and the transfer case is most likley a NP 233 but all you have to do to check is look at the little metal tag on the back side of the case
  4. Thumper
    1,582
    Alberta Canada
    Hehe, thats what I love about this forum! Two replies and two different answers. /forums/images/graemlins/histerical.gif
    Hmm maybe I need to put up a poll /forums/images/graemlins/crazy.gif
    Mike
  5. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    with the transfer case it could be either one my 93 has a 233 but older ones have 231 i do not rember the years of change over. As for the rear GM used two different sizes 10 bolts the larger was used most of the time when there was a gov lock in the axle. Is the 4.3 CPI or TBI
  6. Thumper
    1,582
    Alberta Canada
    Its a TBI 4.3.
    Whats a CPI? Ive never heard that one before.
    Mike
  7. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    4.3 vortec (CPI) or TBI
  8. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    Whats a CPI?
    Central Port Injection
    Uses a throttle body with a rotating injector and 6 tubes down the intake port in the heads.
    Do you have the top part of the radiator shroud?
  9. joshua632
    joshua632 Guest
    I thought the S-10s all had the NP207 /forums/images/graemlins/confused.gif
  10. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    The early ones did. Switched to the 231 and the 233 (elec shift)
    John
  11. joshua632
    joshua632 Guest
    Good to know. /forums/images/graemlins/waytogo.gif
