S-10 Fuel Tank question.....
Discussion in 'The Garage' started by Greg72, Jul 30, 2005.
  1. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    So my dad is feeling guilty about selling me his 1991 S-10 4WD truck with leaky gas tank, but the local mechanic is quoting him $500 to replace the tank, sender and fuel pump.
    My first reaction was "Hey that guys trying to screw you" but then I wondered if there's any weird thing with the S10 where the pump and senders are not removeable or serviceable seperately??? Anyone dealt with this before? The tanks I've seen, you just unbolt the ring on top....gently remove the guts (sender & pump) and then drop them into the replacement tank......right?
    My next question will be about the availablity of a poly tank vs. steel.
    My third question will then be to go post up in the "Parts Wanted" section :D
    I bought the whole truck for only $1000, and don't want my dad getting screwed over paying for a bunch of expensive repairs, especially if it can be repaired as easily as I think it can.
    :deal:
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    there is nothinig special about the s-10 tanks with the sending unit or fuel pump at all. The only reason that i can think that he wants to replace every thing is because the sending unit might be rusted to the tank and not very easy to get off.
    I belive JC whitney carries a poly tank for the S-10
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    if hes replacing all 3, parts and labor that sounds pretty fair to me, hes probably going to replace them cause he thinks they are contaminated. Which if the tank rusted out, is pretty likely. :dunno: I'd do a fuel filter at the same time(you might as well do that).
  4. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    i replaced the fuel tank, sender and pump with straps in my 92 s10 for about 250$
    i actually have a decent tank, sender and pump out of my91 s10 i could get rid of
  5. sweetk30
    Nov 1, 2004
    25,552
    547
    horseheads , ny 14845
    about correct price. most of them when you remove them the lines on the sender twist off from rust. and look at jc whitny for poly tanks. but the time it takes for the new steel one to rust out the truck will mostlikly be gone.
