S-15 running really badly
Discussion in '1983-2005 S-Series models' started by sledjunky, Jan 4, 2003.
  1. sledjunky
    sledjunky Newbie
    Jan 4, 2003
    4
    I am new to this truck and need some advice on the problems with the 4.3 engine. If anyone knows what gets dirty often or what would make this truck run rough please let me know /forums/images/graemlins/smile.gif
    thanks to everyone
  2. davester8022
    davester8022 Registered Member
    Dec 5, 2002
    5
    Stationed in Missouri but hail from Idaho
    Everyone needs more details as to what is running rough, then maybe people can help you. /forums/images/graemlins/deal.gif details, man, details!
  3. sledjunky
    sledjunky Newbie
    Jan 4, 2003
    4
    the engine doesn't want to idle properly.
  4. K5Dan
    K5Dan 1/2 ton status
    Nov 15, 2002
    583
    Port St. Lucie,Fl
    what year is it?
  5. manyblazers
    manyblazers Registered Member
    Dec 13, 2002
    33
    toronto, Canada
    Egr valve is a common problem with these trucks. If you have the vortec engine the proportioning valve under the plennum is notorious for leaking. These trucks got all kinds of problems. Get rid of it and get a real truck. Biggest mistake I've ever made was giving up my full size for one of these roller skates.
  6. sledjunky
    sledjunky Newbie
    Jan 4, 2003
    4
    its an 89 s-15 4x4. The other problem is that when the gas is applied, the truck will not accelerate at a constant, it will fluctuate speeds when the gas pedal is not being moved. The fuel filter has been changed.
  7. Ck1500
    Ck1500 1/2 ton status
    Feb 8, 2001
    198
    Burton, Michigan
    hmmm??? i maybe way off, but i was wondering , how about the Throttle Position Sensor? or even the Ignition Module??? Coil??? i had similar problems, and this Combo fixed it for me, so hopefully it will help ya out, and thank god most of these fixes are pretty cheap!! /forums/images/graemlins/smile.gif
    Ck1500
    Marc
    /forums/images/graemlins/ears.gif
  8. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I'm going to go with the ignition module and distributor cap and rotor.
  9. sledjunky
    sledjunky Newbie
    Jan 4, 2003
    4
    Hey U2Slow, i am from north delta... You go out to stave lake at all?
