?'s about combining lift with 3/4 ton axles
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fourwheelinj1, Nov 12, 2002.
  1. fourwheelinj1
    fourwheelinj1 Registered Member
    Sep 18, 2002
    18
    Wake Forest North Carolina,USA
    ?\'s about combining lift with 3/4 ton axles
    Generally i know that you have to lengthen your drive shafts when you put on a 6 inch lift, but i was wondering if i could get by without lengthing the rear shaft because of the added length of the pinion on a 14 bolt. If so i will also be swapping in a 3/4 ton front axle, so could i get by with just a driveshaft spacer in the front? What is involved in installing a spacer. The blazer is a weekend play vehicle that will be mudding and trail riding lightly, prob less than 5000 miles of driving a year. I would prefer to not have to get a cv driveshaft or longer ones, since i am on a tight budget. I want to put 35's on and winch up front, so i am afraid i will have to trim more than i want with only a 4 inch lift. So will a combination of shims and tranfer case lowering be able to get rid of most of vibs.
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Re: ?\'s about combining lift with 3/4 ton axles
    Well if it was only a length issue you would be right, but the yoke on the 14 bolt is different so you will need a different shaft.
    /forums/images/graemlins/frown.gif
  3. fourwheelinj1
    Sep 18, 2002
    18
    I was planning on just changing u joints.
  4. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I don't think it will be long enough despite the 14 bolt swap.
    Best to lengthen it. About $100 in my area.
    -- Mike
  5. fourwheelinj1
    Sep 18, 2002
    18
    ttt
  6. jackedjimmy350
    jackedjimmy350 1/2 ton status
    Oct 20, 2000
    3,141
    Fort Smith, Arkansas 72901
    i kept my stcok 1/2 ton shaft, just got a cross joint from oreillys /forums/images/graemlins/thumb.gif
