s/flip with zero rates-pinion angle??
Discussion in 'The Garage' started by southernspeed, Feb 24, 2006.
  1. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I posted this on the ORD page but couldn't get an answer. Can anyone help me out with a shackle flip/pinion angle question?
    http://coloradok5.com/forums/showthread.php?t=165088
    please have a look before the mods nuke me for cross posting!:D
  2. 71 Blazer
    71 Blazer 1/2 ton status
    Jul 16, 2005
    184
    windsor virginia
    Didn't need to on my 71 Blazer. What you need to do is do the shackle flip and if you have any problems correct them. Most people don't have to correct the pinion angle with just a shackle flip, go any higher and you probably will.
  3. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    It's just that as I'm having to make some zero rates I thought I'd make some angled ones if necessary. I can't see me needing to alter it but I'd like to hear some opinions. I guess if you've got away with it, I'll be ok. Thanks.
  4. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    It seems to vary by truck. Some do some don't. Do the flip and go drive it. No vibes, no problem. IMO
  5. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    Ya yer at amount of lift where some do some dont. On my Blazer with about 4-5" lift I had degree shims and had to get a CV shaft to get rid of the vibes. While I know of others who were fine. Some just ran degree shims, T-case drop. The best thing would to get er all together then measure the angle and go from there.
