?'s for guy's that made there own draglink for x over
Discussion in 'The Garage' started by captain chaos, Mar 3, 2003.
  1. captain chaos
    captain chaos 1/2 ton status
    Mar 29, 2002
    413
    dickinson, north dakota
    ?\'s for guy\'s that made there own draglink for x over
    i'm looking for the size of tubing you used to make you're drag link.
    i don't know alot about metal specific's, so tell me exactly what to walk into the metal shop and ask for.(please /forums/images/graemlins/smile.gif)
    also i have been told to use es2027L and es2026R drag link end's, is this right?
    i toke a tie rod off one of my spare front's and was going to cut it down and use it. but after looking at it it just seemed to thin and had a little bend in it.
    thank's
    dave
  2. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    Re: ?\'s for guy\'s that made there own draglink for x over
    I used 1.5" DOM (Drawn over Mandrel) tubing, 1/4" wall for my Drag Link. I used the Avalanche tube adapters which are weld on ends that are threaded.
    This has been proven to a few others to be a weak link and I will be re-doing my draglink with the appropriate size for tapping.
    Hope this helps.
  3. white-rhyno
    white-rhyno 1/2 ton status
    Jan 27, 2002
    942
    Ellensburg Washington
    I just took an old tie-rod and cut it up. Then welded it back together. Worked great until i ordered a bent one from ORD.
  4. captain chaos
    Mar 29, 2002
    413
    that's what i am looking for is one that is thich enough to have threaded for the end's.
    was trying to stay away from welding one together for fear of that being the weak link.
    is 1.5 thick enough to do this? if not what is?
    how about the end's??
    dave
  5. Waxer
    1,857
    Long Beach, CA.
    The ends you definitely want to run the ones you listed up above. Those are the 1 ton ends that have a higher degree of movement over the other ones.
