?s on 70-73 k5s
Discussion in 'The Garage' started by DesertDueler, Jan 19, 2003.
  1. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Would a 70 have disc brakes on it? Also how about the u-joint size. I know there are certian years that used smaller u-joints in the front axles, and I know some had drum brakes. Any help is greatly apriciated. I found a great deal on one. Or is a 71, 72, or 73 a better choice, because I have a line up on those as well?
    Dan /forums/images/graemlins/burb.gif
  2. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Re: ?s on a 70 k5
    They used the small U-joint axle shafts thru '72. '71 was the 1st year of front disc brakes. But both of these may have been changed on a '70 by now. My '70 had a disc brake 1/2 ton front axle in it when I bought it 12 or so years ago.
  3. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    i thought i remembered disc as a special order option in 70 maybe i was wrong. if its on there its proably been swapped
    69K5
  4. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    72 is the last year for first gen. 73 came with the larger 297 Ujoint axels(new body style introduced). The larger axels from 73 and up will slide into 69-72 Dana44 fronts.Very easy upgrade.
    Good luck
  5. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    I love the first gens, and I like the 73-75s as well, but really want FI. So I amtrying to decide if I should get a topless k5 or a FI one.
    Dan
