?s on D 44 crossover
Discussion in 'OffRoad Design' started by blazinzuk, Mar 21, 2003.
  1. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    Afton / Star Valley Wyoming
    Hey Stephen I can make the dragling and stuff for a xover steering on my D 44 but is the pitman arm a custom job or is it a stock piece that I can get. Other than a 2wd pickup what other boxes can I use. I might have more questons later I also e-mailed you so you can answer the e-mail or ignore it if you want /forums/images/graemlins/rotfl.gif
  2. Stephen
    Sep 15, 2000
    Carbondale Colorado
    The pitman arm is kind of a custom job for the D44, not an off the shelf part.
    As for boxes, you can use any GM box from the same steering generation as your truck. Basically you have to make sure the input shaft splines and the hose fittings are right for your truck and that's it. Or if you change the pressure hose, or the pump, and the rag joint, you can use any GM box. A lot of dodge boxes will bolt on also but I'm not as familiar with the connections for them.
