?'s on swap from a/c to non a/c
Discussion in 'The Garage' started by roostr34, May 3, 2004.
  1. roostr34
    roostr34 Registered Member
    Mar 24, 2004
    20
    grand rapids, Michigan
    ?\'s on swap from a/c to non a/c
    When I swapped the drivetrain from 1/2 ton to 1 ton and threw in the bbc, I also did some rework to the plenum on the firewall where the blower motor is because I wasnt going to use the a/c anymore. I hacked part of it off because I was told I didnt need part of it anymore, but now I get no heat at all. I cut off the part that is closest to the middle of the truck that covers the last hole in the firewall and just covered that hole up w/ sheetmetal. Everything has been replaced, not sure what else to do. Should I have left the plenum on the firewall intact? any input would be appreciated. Thanx.
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Re: ?\'s on swap from a/c to non a/c
    I would go to a local yard and pull a box of a non a/c truck. I am not an expert on this particular subject, but it sounds like you blocked the airflow through the heater core. /forums/images/graemlins/k5.gif
  3. gm guy
    gm guy 1/2 ton status
    May 1, 2004
    151
    Vancouver Island but work in Ft Mcmurray Alberta C
    I think so to, hit the junkyard.
  4. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    I'm doing this swap also (along with converting from auto trans to manual and power windows to manual... see a theme?) Is anything other than a non A/C heater box and controlls needed for this? I'm almost tempted to just junk the whole heater idea but it gets to be in the negatives around here durring the winter /forums/images/graemlins/yikes.gif
  5. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    You need the whole works from a non-AC truck. You need to cut a new hole in the firewall for the air to pass through. Make a template from the donor truck.
  6. roostr34
    Mar 24, 2004
    20
    I think the j/y is a good idea, actually thats where I got my air box I have now. I havent been able to find a non a/c blazer yet. I looked at the lmc catalog and it looks as though the a/c setup has an additional hole on the firewall compared to a non a/c setup, thats why i covered up thew last hole in the firewall, thinking that it was not needed, obviously I did somethin wrong. I will head back to the j/y and see what I can find, thanx for all the input.
  7. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    It doesn't have to be a blazer donor, could be truck too. Try some cab/chassis trucks as well, most of those were heater only (doesn't apply to southwest). /forums/images/graemlins/k5.gif
  8. u2slow
    May 9, 2001
    2,217
    BC Canada
    I converted my Burb over to non-AC. I had to cover the existing hole in the firewall, and cut a new one. I was in a pinch for parts, so my crewcab became the parts donor /forums/images/graemlins/doah.gif
    Anyway, the only part that was the same from AC to non-AC was the defrost plenum.
