??'s on welders
Discussion in 'The Garage' started by wayne, Oct 5, 2002.
  1. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    ??\'s on welders
    I plan to buy a mig welder sometime for at home. I was looking at the Lincoln Pro Mig 135. It is a 110 volt welder that can weld up to 5/16" in 1 pass. Would something like that be good enough for fabbing bumpers and such? I'm used to big industrial mig welders and the smaller ones I don't know much about so I'm looking for input on what people have and what they do with them.
  2. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    Re: ??\'s on welders
    I had a small one.
    20 amp breaker REQUIRED
    they are pretty optimistic on capacity
    220 in the biggest you can afford is the standard recommendation
    the miller210 is a great bargain currently with the spool gun promo
  3. florida4x4
    florida4x4 1/2 ton status
    Sep 9, 2002
    255
    Florida
    I have had a Daytona Mig Pocket Turbo 130 for about 15 years and it has done wonders. Recently it has been overheating much more quickly than it used to while welding 3/8" rect tubing. I am looking for a 220v welder that has a greater duty cycle that this one (20% @ 130A).
    If you really want to work on heavy stuff I recommend going to a 220V unit to start with. The 110 stuff is best for sheet metal but will get you by in a pinch. Try and get at least 20% duty cycle at 200A.
    Also I dont know about the Lincoln but when I bought my Datona Mig we compared it to a Miller 110v unit and the Miller sucked pretty bad compared to the DM. The DM welds aluminum beautifully (bird netstin rare) and the Miller couldn't keep up. Of course this was in 1986-7 and a lot could have changed with the "toy" Millers...
    thats my .02
  4. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Only problem with a 220 unit is getting power to it. I want to keep it portible which I know you can do with a 220 but I would need a long extention cord for it. I don't have a garage and the only place to run a 220 line is in my bacement.
  5. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I had to run a 50a 220 dedicated circuit for my welder
  6. florida4x4
    Sep 9, 2002
    255
    Florida
    Yeah getting power is a drag.
    For about $80.00 I made a 100' extension cord out of 10ga wire from Home Depot.. that should be good enuf for 200A welder..
  7. jimmy88
    jimmy88 1/2 ton status
    Feb 17, 2002
    351
    Detroit, MI area
    Got to watch the duty cycle. Says it can weld 5/16 in one pass, doutful, but even if it can, for how long can it run that high. Get into some serious fab work you'll be waiting for it to cool down. I use my miller 130xp 110 volt mig for sheet metal and light fab work. Any serious stuff, like bumpers, I use a DC stick welder at work. I like Lincoln, but can't remember why I wound up with the miller.
  8. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I have plenty of time to shop. I used a 115 volt Miller to do my shock mounts and spring perchs on my rear axle and thought that was a good welder.
