???'s on zero rates plus shims
Discussion in 'The Garage' started by Cornfield creations, Nov 30, 2005.
  1. Cornfield creations
    Cornfield creations 1/2 ton status
    Oct 19, 2005
    1,283
    Jasper, Indiana
    On my 79 k-5, I have the original 12 bolt, with 4" TC springs all around, I got my new driveshaft and I need to tilt the pinion up. I ordered a 6* shim from TC and then called the guy back to cancel it. Well it came anyways, so now I have a set of 6* shims. After more research I had my heart set on putting some zero rates under there with a 6* milled into it.
    My question is does it sound unsafe to run zero rates and the shims together? Could I weld them together? and then pin it up?
    Just looking for other opinions. I got 4" lift springs so I wouldn't have blocks,and I don't want to get a chance of having more axle wrap.
  2. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    That is the setup I run.
  3. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Also wanted to know if it was safe...
    Finished setup in the rear of my 84 K5
    2.5" Shackle Flip
    4" BDS springs
    Zero rate
    Degree shim..
  4. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    sounds fine to me. i run zero-rates with a 6* shim, no problems
  5. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    what about a shim and 0 rates up front?
  6. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    I run both up front no problems at all, since the zero rate is basically just like the stock spring pack the shim works just like it does on the original spring!!!
  7. cok5
    cok5 Registered Member
    Apr 27, 2004
    89
    I have seen a 0-rate type design somewhere before that had certain degrees cut into it. Not sure where but I would like to know also.....I need some.
  8. 86Cucvbeater
    86Cucvbeater 1/2 ton status
    May 24, 2005
    428
    north carolina
    Check out the eZero Rate Lift Blocks on this page. http://www.jkwoffroad.com/offroadproducts.php
  9. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,068
    479
    Grand Rapids area
    Just put the center bolt through the shim, the zero-rate and the spring pack all together.
  10. cok5
    Apr 27, 2004
    89
    Thanks, I could not remember for the life of me where I saw those.
  11. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
    Muddytazz can hook you up to....
  12. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    thanks.
