"S" shaped centerlink
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5thatShmobs, Dec 4, 2002.
  1. K5thatShmobs
    K5thatShmobs 1/2 ton status
    Sep 27, 2001
    353
    San Luis Obispo, CA
    \"S\" shaped centerlink
    In the past I can remember seeing "S" shaped centerlinks (aka draglink) that lower to give 2-4 inches of correction. I still need a little extra correction, and this seems like a good fix.
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    Re: \"S\" shaped centerlink
    <font color="green"> I had one of these, personally I think that they are a PITA. A raised steering arm is a better fix.
    Evan </font color>
  3. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    They're made by superlift and they're expensive new... Try and find one used! I just posted a Autozone part #for the ends that are needed with it! Try a search!
  4. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    What you get is just a cure for the ball joints, you will still have the problems of bump steer but you will not wear as much ball joints.
    Go with a raised steering arm.
  5. k5blazerus
    k5blazerus 1/2 ton status
    Apr 22, 2001
    654
    Bend, OR
    Hey Batmanir. What are the part # at autozone for the superlift drag link ends.
    Colin
  6. K5thatShmobs
    Sep 27, 2001
    353
    San Luis Obispo, CA
    I have a raised steering arm and a dropped pitman, but the centerlink still sits at a crappy angle. Im not sure what the correction is on both of those though. Who makes an "S" shaped besides superlift?
  7. Batmanjr
    Mar 23, 2001
    1,537
    That is usually the case with the people that use a drop draglink... They already have a 4"-6" raised steering arm and/or a drop pitman arm... All they need to do is correct the problem slightly... I found the drop draglink attached to something I already was getting, didn't know I was going to need it till now. Since I did, I searched to find ends! The issue I see, is that most people on this site are quick to assume.... Yes, it is better to use a drop pitman arm or raised steering arm, but sometimes that isn't enough! Now about the bump steer, I slightly disagree unless that is all you plan on using... The Drop pitman arm does the same effect on correcting the proble on the road, offroad, as long as you're still running the drag link to the left side, you're always going to have a problem with bump steer! Again, I don't suggest using the drop draglink as a correct all to use alone, go raised steering arm or drop pitman.... But to correct a slight angle or to gain the right angle after all else used, It definately helps.... Also, most times in my experiance, a bad steering stabilizer is the cause of poor bumpsteer, not a drop draglink!
    The Auto zone Part # for the ends are as follows:
    Superlift Drop Drag Link Ends:
    AutoZone: ES2234R $24.99 /forums/images/graemlins/thumb.gif
    Superlift: 3040-1 $49.99 /forums/images/graemlins/eek.gif
    You have to shorten the 2234R by 1.5" with a hacksaw, but other than that, Priceless!
    /forums/images/graemlins/grin.gif
  8. k5blazerus
    Apr 22, 2001
    654
    Bend, OR
    HEy tanks for the part #. Is that part # for both ends.
    Colin
  9. K5thatShmobs
    Sep 27, 2001
    353
    San Luis Obispo, CA
    Wait, so the autozone ends are for the superlift dropped link without the ends? Or are they angled ends I can use with the stock draglink?
