S&W Cage Pics
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Mudzer, Mar 8, 2002.
  1. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    I have posted some new pics of my cage install. Only took about 4 hours to install this.
    <a target="_blank" href=http://community.webshots.com/album/32175390UMgImrALhW>Cage Pics</a>
  2. Scooter
    Scooter 1/2 ton status
    Nov 18, 2000
    551
    Grandview, Mo.
    Looks good Neil!
  3. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    That looks really good! Did they have a kit which covers the back seat as well? If not, do you think a second kit could be modified to attatch on easily? You can't beat the price on these things. How long did it take you?
  4. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    They have an add on for like $40 or somehting close to that, that will cover the rear seats also.
    Ken H.
  5. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    Do you have to remove the stock parking brake lever?
  6. four_by_ken
    Jun 9, 2001
    3,806
    Allenton, MI
    I dont know, I never put one in.
    Ken H.
  7. four_by_ken
    Jun 9, 2001
    3,806
    Allenton, MI
    I cant tell from the pictures... is this a bolt in or weld in kit?
    Looks good.
    What was the told cost with shipping?
    Ken H.
  8. Mudzer
    3,639
    Missouri
    I did not have to modify the parking brake levers. I did trim the corner off my dash plate and removed the screw. I didn't want to have problems later when I needed to remove the dash. My Cage is welded in totally. I welded in 3/16" Plate on the floors. The kit comes with more bars than I installed, but I didn't find them necessary. I installed the smaller Gusset Tubes myself. The Cage is very rigid. I plan to install a rear cage soon, just ran out of time.
  9. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    So, what was the total cost? I need to put a full cage in mine since the whole top comes off, so I know mine'll be more, but I just want to get an idea of how much I'll be spending. Thanks!
  10. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Is there enough extra material on that top halo to go through the dash? Or is it already cut to length?
  11. Mudzer
    3,639
    Missouri
    Russ,
    You will notice I installed my cage approximately 6" further back than I could have. The Halo comes a little long, and is pre-notched. There are several tubes which are not pre-notched. I used paper, scissors and a marker to transfer the pattern needed to be cut out. I used a plasma cutter and grinder to notch my tubing. It worked great. I did do one modification though. The way the halo was bent, it would have been much lower on the main hoop. So, I stuck it in my "poor mans bender" (2" receiver on my truck!) and tweaked both legs of the "U" inward about 2". This allowed me to install the halo higher on the main hoop. I wanted it tight to the roof. I belive this cage could have been installed through the dash without many modifications. I just did not have time to remove all the dash components to do this. I think the cage turned out fine without going through the dash. I am no finished with this cage kit. I will have a race car fabricator finish the rear portion for me. I am either tying it into my existing factory rear roll bar, or designing something different that will cover passengers. Here are the bars I did not use: Two short diagonals used from main hoop shoulder bar down to the tranny hump, door bars and rear support bars. Essentailly, mine is only a 4 point cage at this time. Soon it will be finished.
    The cage cost me $254 shipped to St. Louis. It came in 4 bundles and came with 6x6-1/8 plates for mounting to the floor. I would rank the quality of this kit high. Its definately worth it if you can weld. My siblings bought my Dad a new Miller 110v Gas Mig and Auto-Darkening helmet for Christmas (lucky me!). The 110 is good for doing projects like this with up to 1/4" thick material. I have learned to weld with a mig over the years so I was confident I could do this. I removed all the carpet and seats, then started cutting out rusty floor pans. I installed 3/16" plate to replace the rusty floor, then welded the cage to that.
    I still plan to install the rear cage, plus some bars which go from the main hoop to the front of the halo to keep the bar from collapsing from a diagonal load. These will have some funky bends to make them clear the passenger/drivers heads. I will also install some grab handles.
  12. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Thanks for the info. BTW, nice job, it really looks good. Got me thinking about S&amp;W again, that's why I asked. I just want it closer to the A pillars and it sounds like that will work fine. Mine is pretty much gutted so I think it would go through the dash a little easier. If not, I don't mind cutting the wee out of it if need be. /forums/images/icons/laugh.gif
  13. BigTex
    BigTex 1/2 ton status
    Dec 27, 2000
    974
    South Texas
    Very cool, Neil. What kind of liner is that? Did you do that yourself? Is it a roll-in?
  14. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Thanks for all the info, I bought a bunch of 1 1/2 DOM tubing to make my own cage but lack a tube bender. I think I'll use that for rock sliders and go the same route you have. Your info would make a good write up for the site (hint hint Steve).
  15. Mudzer
    3,639
    Missouri
    Glad I could help guys. I may contact S&amp;W to see if they would give us a discount for a writeup. I already payed for mine, but would like to pass on the savings.
    BigTex, my bedliner is Herculiner from AutoZone. It rolls on without major pains. You will need to buy some Acetone, MEK or Xylene to clean with, plus a small paint tray, but the kit for $89 comes with everything else. AutoZone had a special for $20 rebate from Herculiner. Perhaps you could acquire about this.
  16. four_by_ken
    Jun 9, 2001
    3,806
    Allenton, MI
    Dont CK5 members already get a 10% discount through S&amp;W?
    Ken H
  17. four_by_ken
    Jun 9, 2001
    3,806
    Allenton, MI
    Man, I just checked it out... guess not, no discount. But they do have the 8 point cages on sale for $109 right now. Then like $40 for the rear add on. Just might have to bump up the cage on my list of priorities.
    Ken H.
  18. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Lookin' good/forums/images/icons/smile.gif
    Couple of questions for ya'
    Whats the pipe dia?
    Wall thickness?
    Mild-steel, or Chromoly? (I thought they were Chromos', for some resson)
    How much do you think it weighs?
    Thanks!
  19. Mudzer
    3,639
    Missouri
    The Cage is made from 1 3/4" x .134" wall Mild Steel tubing. I would say it added approximately 100 pounds to my vehicle.
