S & W cages
Discussion in 'The Garage' started by 55Willy, May 25, 2003.
  1. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    Who here is running a weld together kit from S&W? I'm looking at getting one but need some info first.
    How well did it fit?
    Do you run a full topper or half top?
    Any pics??
    My main concern is the 2nd bar(main loop behind seats) I need a width and hiegth to see if it will work in the wagon, since I have the blazer floor it can't be too hard to make it fit.
    -Jeremy
  2. slimlynn1
    slimlynn1 1/2 ton status
    Apr 9, 2003
    336
    Hamden, CT
    I'm in the process of putting one in now in my 88 K5. I will let you know how it comes out. I will also post some pictures. It seems like there will be allot of cutting, depending on where you mount the main hoop. I wanted the main hoop inside the half top so all of the front pieces will have to be cut.
  3. slimlynn1
    Apr 9, 2003
    336
    Hamden, CT
    Here is the progress of the S&W roll cage install. I have the main hoop the rear supports and the seat cross bar installed for now. I purchased a 10 point but I think I will stop here for now. Too many other things to do. The fit was pretty good, so far I cut down the main hoop 1/2 inch and I ground the rear supports a little to get the right angle. Here are some pictures.
  4. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    looks awesoem, can I ask ya favor???? can ya pull a tape on the main hoop for me. I'm wonder if I have to narrow all of it up...also I was planning on the 10 point cage too but change the rear set up to better fit my needs.
    -Jeremy
  5. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    Im liking it so far, keep us updated. /forums/images/graemlins/thumb.gif
  6. slimlynn1
    Apr 9, 2003
    336
    Hamden, CT
    I'm at work now so when I get home I will measure the main hoop for ya.
  7. slimlynn1
    Apr 9, 2003
    336
    Hamden, CT
    I measured the main hoop at the widest point and it is 64 1/2 inches wide. About 1/4 inch on either side. What are you putting it in? They might have one for your application, or onr that is a little closer in width like a S-10 or some thing.
  8. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
  9. slimlynn1
    Apr 9, 2003
    336
    Hamden, CT
    I havent installed my front supports yet, what did you do about the door handles. I think I will have to remove mine so I can close the door. Looks great! /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif Is it tied to the frame at all? Do you have any more pictures?
  10. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    My floor is a blazer, basicly my outside wall is your inside wall. I figured the blazer would be the closest in fitting. It's going in my wagon.
  11. bablazer73
    Apr 4, 2000
    3,363
    upstate ny
    I Have a couple more pics, but my computer is really retarded and can't get them to post! The door handles are fine. The armrests hit the down tubes. I am gonna make some sort of door flat panel
