S10 blazer 4X4 SAS conversion
Discussion in 'The Garage' started by BackDoor-Banditt, Nov 6, 2006.
  1. BackDoor-Banditt
    BackDoor-Banditt Registered Member
    Mar 11, 2006
    14
    port richey, Florida
    hey yall ive got an 87 S10 blazer 4X4 that im thinking about converting from IFS to SAS but what front axle, leaf springs, and steering should i use?
  2. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    toyota, toyota with orbit eyes, custom
  3. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,010
    7
    Binghamton NY
    if you want close to stock width, go with Waggy 44s fron and rear. Different ways of doing the front. Can go SUA, use all the susp. stuff off the Jeep, or can go SOA, then you could use stock rears off an S-10 with an add-a-leaf or two, or stock type fronts off 73-91 4wds, but have to mount the rear spring hanger on the bottom of the frame. The longer springs can mount inside the frame, like the 88-up fullsize SASs. Pretty much havta go crossover, either to the pass knuckle or to the tierod, depends on how much lift....
  4. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
  5. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
  6. OrangeCrushK10
    OrangeCrushK10 1/2 ton status
    Jan 25, 2003
    1,425
    Square State + Suspension Item
    Go with D44's from a Wagoneer. They are by far the best way to go that I've heard of. Everything from the pitman arm down.
