s10 blazer 4x4 to zr2
Discussion in 'The Garage' started by jekquistk5, Aug 15, 2006.
  1. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,005
    830
    Pinckney, MI
    Well Zr2.com is no help, they denied my acess to post because I do not have a zr2(no picture). I was wondering if you can take zr2 IFS parts and put them on a non zr2 blazer to lift it a little. TJ(big83chevy4x4) thinks the frames are different, but can anyone conform this for me. The rear shouldn't be a problem, the front is what I'm not sure of. I should be getting a 99 blazer for very cheap from my parentals, and kinda want to make it a dd/ weekend warior. Trying to fit 31-33's...
  2. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    I don't know if the frames are different. I know the zr2 had a way wider track width than a stock s10 I am thinking the front of the frames are different cause you can't use a normal s10 lift on a zr2
  3. BadBob
    BadBob 1/2 ton status
    Aug 14, 2005
    158
    Lyndon, KS
    The frames are substantially different. The rear axle is also 4" wider on the ZR2.
  4. jekquistk5
    Jan 18, 2004
    11,005
    830
    Pinckney, MI
    Well it looks like I'll have to just crank the Tbars and get longer shackles for now, then save up for a lift or do SAS right of the bat..... Hmmm I do have a spare front 10blt:rolleyes::rolleyes:
  5. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    The frame is quite different. That's where the lift and front track width is created.
    You'd get a similar look by running conventional offset wheels, adding a body lift, and cutout flares.
  6. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    zr2 rear leaves will provide lift on a standard s10 but have a lower load capacity(quite a bit lower if I remember right)
  7. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    When we were dissecting our S10 for SAS, I was brewing some ideas about a home brew lift. It involved swapping the torsion bars, left to right, right to left. I think it would give you about 3-4" of lift. Then alignment would be the only issue, you could probably look into a ball joint flip or something. Or you could buy some used A-arms. Oh wait....I still have a superlift kit laying around here too....:deal:
  8. jekquistk5
    Jan 18, 2004
    11,005
    830
    Pinckney, MI
    well I'm not going to buy anything until I buy the blazer... I really dont want to do the body lift b/c everyone says it looks retarded b/c the frame hangs soo low. We shal see when the day comes, I was just tossing arround ideas. Its not the zr2 look i'm too worried about, I just hate the small azz tires on it. I want it a little taller, with some good tires, so its capable off road. I do want it to not look like a hack job though b/c I will be driving it everyday
  9. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    do a sfa, it can be cheaper than buying a lift, and you can get a good amount of lift out of it, i just got a s-10 sitting on a sfa and with 4 inch springs it is at about 10 inches of lift
  10. big94gmc
    big94gmc 1/2 ton status
    Sep 1, 2004
    3,651
    No VA.
    WTF??
  11. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    Well it's hard to do a SFA without going with a lot of lift. I think our's came out to 13-14" of lift, which is good for about the 35-38" tire range. Sounds like he'd like to keep things fairly mild though.
  12. u2slow
    May 9, 2001
    2,217
    BC Canada
    They are 5-leaf as opposed to 3-leaf on most S10 models.
  13. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    Hmm, we've got some 3 leaf ZR2 springs in the back of our SAS project. I don't know what era S10 they're from though.
