Saddle Tank Filler Neck
Discussion in 'The Garage' started by ProJunkRacing, Nov 21, 2005.
  1. ProJunkRacing
    ProJunkRacing 1/2 ton status
    Jun 20, 2005
    1,229
    FrankFort IL
    I got an 86 Shortbox and I have saddle Tanks, I was just wondering where I could get A filler neck and whatnot for the tank , also I run Carb , and there are 3 outlets on the sender, I used the biggest for my feed line what are the other 2 what should I do with them?
    Any Ideas , help Just trying to wrap this project up
  2. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Others are return line and a vent line.
  3. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    do i need the return line or no?
  4. seattle73k5
    seattle73k5 1/2 ton status
    May 6, 2005
    210
    San diego/Camp Pendleton
    No return line is needed, if you are running just a carb.
    you can get a fender filler kit for your sadle tank from any distibutor that sells Jaz fuel products, I got mine from them.
    good luck.
  5. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    is that factory location?
  6. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    whats wrong with the factory fillers that i gave you? :confused:
  7. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    My '86 C10 is OEM from factory with carb. It has a return line. Whether it's needed or not, I don't know, the factory thought it was. Mabey it's not though.
    Look at your fuel pump, it will tell you if you do. Was the truck originally carbed, or was efi converted to carb. My truck has a mech. fuel pump with three outlets, 1 from tank(s), 1 to carb, and 1 retrun to tank(s). If you only have 2 outlets on your fuel pump, then you won't need the return line.
    If you have a elec. fuel pump, I can't help you, I've never dealt with all that new stuff!
  8. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    originally carbed when i got it, i believe he's still running the carb. there were 3 ports on the stock fuel pump. its in my 73 now.
  9. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    i never thought of that wish i still had those tanks
    oops lol
  10. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    yeah elec fual pump inline so therefor i will run no return i guess ,but do i cap the outlet and just use a vent or what
